how do i calculate change in velocity?
by HelloMotto
Tags: velocity
HelloMotto
HelloMotto is offline
#1
May11-08, 10:05 AM
P: 74
An airplane is flying at 2.00 x 10^2 km/h [S30.0W]. It makes a smooth wide turn and heads east at 2.00 x 10^2 km/h. Find its change in velocity.
2. Relevant equations
v = vf - vi
3. The attempt at a solution
the directions are throwing me off. What do i do after i draw it out? Can you guys tell me the answer plz? so I can make sure I did the question right
thank you if you can help.
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
HallsofIvy
HallsofIvy is offline
#2
May11-08, 10:17 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 38,896
No, we cannot tell you the answer. I did write out suggestions as to how to do vector problems in general and then looked at the directions given here!
Initially, the airplane was flying at 200 miles per hour due west It turned around and is flying at 200 miph due east. If you were to write "200 miles per hour due west" as +200 mph, what would "200 miles per hour in the opposite direction" be?
HelloMotto
#3
May11-08, 10:41 AM
P: 74
theres is [S30.0W] and then it turns to east.... how do i calculate with this weird angle in the question?
Redbelly98
Redbelly98 is offline
#4
May11-08, 11:11 AM
Mentor
Redbelly98's Avatar
P: 11,989
Quote Quote by HelloMotto View Post
[S30.0W] probably means either 30 degrees south of due west, or 30 degrees west of due south. It must have been explained by your teacher or in your textbook.
Looks like expressing the velocity vectors in terms of components (x and y) will be useful here.
Register to reply
Related Discussions
Use the experimental values to calculate the enthalpy change in the system. Biology, Chemistry & Other Homework 1
Calculate velocity Introductory Physics Homework 3
How to calculate the change in R or displacement. Introductory Physics Homework 2
How can you calculate change in magnetic flux? Introductory Physics Homework 5
Is the magnetic field change linear with the velocity change of a particle? General Physics 1
