How Does Partial Wire Insulation Affect Beakman's Electric Motor Functionality?
The discussion centers on the impact of partial wire insulation on the functionality of Beakman's electric motor. It is established that completely removing insulation from one end of the wire ensures constant contact with the battery, while sanding off the top half of the insulation on the other end allows the coil to be active only half the time. This alternating activation is crucial for the motor's operation, as it prevents opposing magnetic forces from canceling each other out, thereby facilitating continuous rotation.
  • Understanding of basic electrical circuits
  • Familiarity with electromagnetism principles
  • Knowledge of wire insulation types and their effects
  • Experience with DIY motor assembly techniques
  • Research the principles of electromagnetism in depth
  • Learn about different types of wire insulation and their properties
  • Explore advanced motor design techniques for improved efficiency
  • Investigate the application of Flemming's left-hand rule in various electrical devices
This discussion is beneficial for hobbyists, educators, and students interested in electrical engineering, particularly those focused on DIY motor projects and electromagnetism applications.
KLscilevothma
http://fly.hiwaay.net/~palmer/motor.html
In step 2, it says
On one tail, use fine sandpaper to completely remove the insulation from the wire. Leave about 1/4" of insulation on the end and where the wire meets to coil. On the other tail, lay the coil down flat and lightly sand off the insulation from the top half of the wire only. Again, leave 1/4" of full insulation on the end and where the wire meets the coil.
Why we should remove the insulation from one side of the wire while to sand off the insulation from the top half of the other end of the wire? What if we remove all the insulation from both ends of the wire? And what happen if we remove all the insulation of the wire?
By Flemming's left hand rule, we can work out the polarity of the magnet used.
I've made this motor before, it's easy to make, and pretty cool!
The reason to entirely remove the insulation from one side of the wire is so that it is always in contact with the battery (through the paperclip).
The reason to remove 1/2 the insulation from the other side of the wire is so the coil (electromagnet) is only on, or active, 1/2 the time. This way you can get the coil-magnet and ceramic-magnet to "push" against each other without them "pulling" each other 1/2 the time, which would keep the coil from spinning.
Remember if a north-pole end of a magnet is near a north-pole end, it will repel, but if a north-pole end is near a south-pole end it will attract. If we have equal "pulling" and "pushing", the forces will cancel each other out. If we only do one or the other, there is no other force to cancel.
got it! Thank you
  • · Replies 19 ·
10K
  • Sticky
  • · Replies 705 ·
24
125K
