Calculating Beat Frequency in Ultrasound Doppler Effect
The discussion centers on calculating the beat frequency resulting from the Doppler effect in ultrasound, specifically for a bloodstream moving at 30 cm/s and an original frequency of 2.5 MHz. The correct approach involves accounting for two frequency shifts: first, the increase in frequency perceived by an observer moving with the bloodstream, and second, the reflection of that frequency back to the original observer. The final calculated beat frequency is 974.2 Hz, confirming the necessity of considering both shifts in the Doppler effect calculation.
  • Understanding of the Doppler effect in wave physics
  • Familiarity with ultrasound frequency calculations
  • Knowledge of sound velocity in different mediums, specifically blood
  • Basic mathematical skills for frequency and velocity calculations
  • Study the principles of the Doppler effect in detail
  • Learn about ultrasound frequency modulation techniques
  • Explore the mathematical derivation of beat frequency in wave interference
  • Investigate the applications of Doppler ultrasound in medical diagnostics
Physicists, medical ultrasound technicians, and students studying wave mechanics or acoustics will benefit from this discussion, particularly those interested in the practical applications of the Doppler effect in medical imaging.
jjlittel
I have been trying this problem for a couple of days:
Ultrasound reflected from an oncoming bloodstream that is moving at 30 cm/s is mixed with the original frequency of 2.5 MHz to produce beats. What is the beat frequency? (Velocity of sound in blood = 1540 m/s.)
I tried this as a doppler effect problem where the frequency is
(original frequency)*{v/(v-velocity of source)}. I then subtracted that from the original frequency to find the beat frequency, and came up with 487.1 Hz, but that was not the right answer. For v, I used 1540 m/s, and velocity of source was 0.3 m/s. Is there something I am missing in my approach to the problem?
I think you have to solve this with two shifts.
Consider a second observer riding along with the oncoming bloodstream. This observer is moving toward the original source & therefore perceives an increase in frequency. So the reflected wave starts out with a shifted frequency, which is then shifted again because it's source (the oncoming bloodstream) is moving toward the original observer.
Thank you for the help, gnome. You were right about the second shift, and I finally got the answer, which was 974.2 Hz.
