Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Srednicki Share It Thread Tools Search this Thread image
Old May12-08, 11:03 AM                  #1
Icosahedron
Icosahedron is Offline:
Srednicki
Could someone help me how in this book by Srednicki I get from eq. 54.23 to 54.24?
thank you
(The book is free on the net, I'm not allowed yet to post the link on this forum, maybe some other can do.)
Old May12-08, 12:21 PM                  #2
DavidWhitbeck
DavidWhitbeck is Offline:
It's just simple math, there are no sneaky tricks there. Start with 24 and plug in the formula for K. Excepting two terms you should be able to cancel all of the terms in the first group with the terms in div K, leaving you with eqn 23.
Old May12-08, 05:40 PM                  #3
Icosahedron
thanks David, but I still can't see it. Where does the first term in 5.24 come from? I just see that the last two terms in 5.24 are 5.23, but the first term in 5.24??
Old May12-08, 05:53 PM                  #4
DavidWhitbeck
When you use the product rule on the first term on div K you will get the first term in 5.24, but with opposite sign and they will cancel.
The thing is that LaTeX Code: \\partial_\\mu \\partial^\\mu = \\partial^2 the d'Alembertian operator, and LaTeX Code: A^\\nu=g^{\\mu\\nu}A_{\\mu} where LaTeX Code: \\mu is a different index! The first one was already summed over.
Old May13-08, 03:18 PM                  #5
Icosahedron
OK, got that.
The thing is that the d'Alembertian operator, and where is a different index!
I also understand what you are saying here. But still I can't see, even after starring another 30 minutes on the equation, how that get me to that first term in 54.24.
Old May13-08, 03:43 PM                  #6
nrqed
nrqed is Offline:
Recognitions:
Homework Helper Homework Helper
Originally Posted by Icosahedron View Post
OK, got that.
You have to add that term in order to be able to subtract LaTeX Code:  \\partial^\\mu K_\\mu  at the end.
Here is the way to do it:
Take 54.23. Now add zero in the form LaTeX Code:  \\partial^\\mu K_\\mu - \\partial^\\mu K_\\mu  .
Now expand out the positiveLaTeX Code:  \\partial^\\mu K_\\mu  , leaving the subtracted one in the form LaTeX Code: - \\partial^\\mu K_\\mu  . You should recover 54.24
Old May14-08, 03:15 AM                  #7
Icosahedron
But I don't get the indices match, I don't get them up and down like they supposed to in 5.24. The two upper indice partial derivative in 5.24, where does that come from?
On the same page on the second to last line, the author does this trick again, but I can't see how.
Old May14-08, 11:39 AM                  #8
malawi_glenn
malawi_glenn's Avatar
malawi_glenn is Offline:
Recognitions:
are we talking about eq 5.24 or 54.24?
Old May14-08, 12:07 PM                  #9
nrqed
nrqed is Offline:
Recognitions:
Ah, I see your problem.
Consider the expression
LaTeX Code:  A^\\nu \\partial^\\mu \\partial_\\nu A_\\mu
First, you can relabel mu -> nu and nu -> mu (they are summed over so you may rename those indices) This gives
LaTeX Code:  A^\\mu \\partial^\\nu \\partial_\\mu A_\\nu
The next trick is to use the fact that you may lower the index mu on the gauge field if you move up the corresponding index on the partial derivative, which gives
LaTeX Code:  A_\\mu \\partial^\\nu \\partial^\\mu A_\\nu
Using this and the approach I mentioned in my previous post, you should get the result.
Old May14-08, 02:11 PM                  #10
Icosahedron
Now I see!! thanks everybody
After I took up so much of everybody's time over such a trival matter, has someone the nerve to look at 55.4? Is there a quick way to see that this gives the Coulomb gauge? Just a hint would be fine.
thank you
Old May14-08, 02:24 PM                  #11
nrqed
nrqed is Offline:
Recognitions:
thank you
the idea is this: Consider a totally arbitrary A_j. Now, consider the expression on the rhs of 55.4 (where A_j is still completely arbitrary). Let's call this LaTeX Code:   P_{ij} A_j  . It's clear that this expression obeys
LaTeX Code:  \\nabla_j (P_{ij} A_j) = 0
Therefore the quantity LaTeX Code:   P_{ij} A_j  can be used to represent a gauge field in the Coulomb gauge (where, again, the A_j that is there is arbitrary)
Old May14-08, 02:30 PM                  #12
DavidWhitbeck
I think the simplest way to see that you are now in the Coulomb gauge is to do as Srednicki says and look at div A in k-space. You can see that LaTeX Code: k^i \\tilde{A_i}=0 which implies that in x-space that LaTeX Code: \\nabla^i A_i = 0 .
Old May14-08, 03:00 PM                  #13
Icosahedron
thanks David!
or k_i(d_ij - k_i *k_j/k^2)= k_j - k_j = 0
I hope that's readable, not good at that latex thing (d is Kronecker delta)
Old May14-08, 03:13 PM                  #14
DavidWhitbeck
Exactly! Bingo.
Oh and also in k-space it easily looks like the classic projection operator that we're all used to from vector algebra/calc. I'm uncomfortable with the differential operator version because of that inverse Laplacian operator, very funky.
Old May14-08, 04:11 PM                  #15
Icosahedron
Again thanks nrqed, thanks David.
I will now read on but I'm afraid I will have to return to this thread sooner or later.
But so far, thank you guys!
Old May14-08, 04:29 PM                  #16
DavidWhitbeck
Enjoy the studying! I love that book, it's the first one that made qft make sense to me. I haven't gotten as far into it as you have, not by far.
image image
Reply
Thread Tools
Similar Threads for: Srednicki
Thread Thread Starter Forum Replies Last Post
Qft question (Srednicki) trinitron Quantum Physics 14 May30-08 11:55 AM
Srednicki problem (8.8) hawcheese Advanced Physics 1 Nov5-07 07:40 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
