What are the galactic coordinates of the Cosmic Microwave Background hotspot?
  • Context: Graduate
  • Thread starter Thread starter marcus
The Cosmic Microwave Background (CMB) hotspot is located at equatorial coordinates (11 h 12 m, -7.22 degrees) and corresponds to a galactic position of (265.3 degrees, +48.2 degrees) as calculated using Murphy's online calculator from Johns Hopkins University. This aligns closely with the COBE team's published coordinates of (264 degrees, +48 degrees) in their 1996 paper. The speed of the solar system relative to the CMB is approximately 1.23 E-3 times the speed of light, which translates to about 367.4 kilometers per second. The discussion highlights the utility of the calculator for converting celestial to galactic coordinates.
  • Understanding of celestial and galactic coordinate systems
  • Familiarity with the Cosmic Microwave Background (CMB)
  • Basic knowledge of astronomical speed measurements
  • Experience with online astronomical calculators
  • Explore the COBE team's 1996 publication on the CMB hotspot
  • Learn how to use Murphy's online celestial to galactic coordinate calculator
  • Research the significance of the CMB in cosmology
  • Investigate the implications of the solar system's motion relative to the CMB
Astronomers, astrophysicists, and students interested in cosmology and the Cosmic Microwave Background, as well as anyone utilizing celestial coordinate systems in their research.
marcus
Dearly Missed
http://fuse.pha.jhu.edu/support/tools/eqtogal.html
An astronomer named Murphy at Johns Hopkins University
has provided an online calculator going from celestial to
We should try it out, and so, for instance
In 1996 the COBE team published
http://arxiv.org/PS_cache/astro-ph/pdf/9601/9601151.pdf
"The Dipole Observed in the COBE DMR Four-Year Data"
In which they said that the Cosmic Microwave Background hotspot was located at
And that it corresponded to a speed of 1.23 E-3
(1.231 +/- 0.008 x 10-3 is what they actually said
but for convenience I'm not giving confidence intervals)
I was pleased to see that they expressed the solar system's speed relative to the CMB as the fraction of the speed of light just quoted, as well in the usual way.
They also gave galactic coordinates for the hotspot, which can provide a check of Murphy's calculator.
(11 h 12 m, -7.22 degrees) happens to be in the constellation Leo.
I find that if I put those equatorial coords into the calculator it gives me (have to do this and get back...) galactic coords:
This is pretty close to what the COBE team published for the galactic coordinates of the hotspot, which was:
I rounded off their figures which had a couple of more decimal places and confidence intervals in the last two digits, which I don't show. So it is not surprising to get an answer that's a degree different---calculator itself is approximate---but anyway close enough.
If the hotspot is in Leo the cold spot would be in Aquarius or thereabouts.
If you want the speed of the sun's motion w/rt CMB to be in meters per second, as you should if you use metric units exclusively, then multiply their figure of 1.231 E-3
by 299792458 meters per second. For my part I shall think of the the sun's speed relative to the expansion of the universe as
1.23 thousandths of the speed of light.
Leo has been in the sky a lot of evenings this spring
Astronomy news on Phys.org
