Thread Closed
klein gordon equation
Share Thread
May15-08, 01:35 PM   #1
I am being really thick here
I have this wave equation, the massless klien gordon equation
[tex]\partial_{\mu}\partial^{\mu}\phi(x)=0[/tex]
where the summation over [tex]\mu[/tex] is over 0,1,2,3
the general solution is a superposition of plane waves yes? i.e
[tex]\phi(x)=\int d^4 p \overline{\phi}(p)exp(i p_{\mu}x^{\mu})[/tex]
where [tex]\overline{\phi}[/tex] is the weighting function.
When you susbsitute this back into the klein gordon equation you get down two factors of p, i.e
[tex]p_{\mu}p^{\mu}[/tex] which equals zero. (mass shell constraint), thus satisfying the equation of motion.
My question is, is [tex]\overline{\phi}(p)[/tex] arbitrary? I don't really understand why this is so, let alone believe it.
Hope peeps understand the question.
PhysOrg.com physics news on PhysOrg.com
>> Is there an invisible tug-of-war behind bad hearts and power outages?
>> Penetrating the quantum nature of magnetism
>> Rethinking the universe: Groundbreaking theory proposed in 1997 suggests a 'multiverse'
May15-08, 03:09 PM   #2
neu
The superpostion equation you wrote is simply the fourier transform of [tex] \phi (x)[/tex].
[tex] \phi (p)[/tex] are not arbitrary as [tex] \phi (p) = FT^{-1}[\phi (x)][/tex]
Have I misunderstood your question?
May15-08, 03:38 PM   #3
yeah I understand that.
I'm being really thick here.
I want the general solution [tex]\phi(x)[/tex] to the equation, ie as a superposition of plane wave solutions, but in fourier space.
Ultimately I want to know what [tex]\overline{\phi}(p)[/tex] is.
May15-08, 03:45 PM   #4
What I mean is, if [tex]\overline{\phi}(p)[/tex] is one weighting function whose fourier transform solves the klein gordon equation and [tex]\overline{\psi}(p)[/tex] is another different weighting function is the fourier transform of [tex]\overline{\psi}[/tex] also a solution.
May15-08, 04:31 PM   #5
Well, any [tex]\phi(p)[/tex] will make [tex]\phi(x)[/tex] a solution. These are merely coefficients in your Fourier expansion. However, once you write the Hamiltonian in terms of [tex]\phi(p)[/tex] and [tex]\pi(p)[/tex], you will find that it simplifies greatly (decoupled harmonic oscillators, one for each p), and quantization is the next step.
May15-08, 04:54 PM   #6
Well, any [tex]\phi(p)[\tex] will make [tex]\phi(x)[\tex]a solution
great as long as you're sure about that. That's what I hoped.
I have guessed some expression between [tex]\phi(p)[\tex] and a whole load of other stuff and I want to test my conjecture on the computer. So, presumably I can just invent some suitable function for [tex]\phi(p)[\tex] stick it into a c-program and check it works.
May15-08, 07:40 PM   #7
Recognitions:
Homework Helper Homework Help
Quote by bartadam View Post
As others said, phi(p) is arbitrary. The way to see this is the following: plane waves (with the condition on p^2) are solutions of the equation and the equation is linear, therefore arbitrary linear combinations of plane waves will satisfy the equation. Therefore phi(p) is arbitrary.
May15-08, 08:18 PM   #8
Recognitions:
[itex]p_{\mu}p^{\mu}[/itex] which equals zero. (mass shell constraint), thus satisfying the equation of motion. [...] is [itex]\overline{\phi}(p)[/itex] arbitrary? [...]
Adding my $0.02 to what others have already said, the [itex]\overline{\phi}(p)[/itex] is not
entirely "arbitrary", because you have imposed the mass-shell constraint [itex]p_{\mu}p^{\mu}=0[/itex].
Think of that as a "constraint hypersurface" in 4D momentum space.
I.e., [itex]\overline{\phi}(p)[/itex] is undefined for values of p which are not on
the constraint hypersurface.
May15-08, 08:26 PM   #9
Recognitions:
Quote by strangerep View Post
True but this is not a condition on the functional form [itex]\overline{\phi}(p)[/itex], it's a restriction on the argument p. I mean, as long as p is a valid p, any function phi(p) is valid, right?
A different consideration arises if we consider localized wavepackets phi(x). Then there must be a condition on phi(p).
May15-08, 08:35 PM   #10
Recognitions:
Quote by nrqed View Post
Yes and yes.
Thread Closed
Similar discussions for: klein gordon equation
Thread Forum Replies
Klein-Gordon equation for electro-magnetic field? Quantum Physics 27
[SOLVED] Klein Gordon equation, probability density Advanced Physics Homework 1
understanding Klein-Gordon Quantum Physics 3
Klein-Gordon Equation Advanced Physics Homework 14
klein gordon equation Quantum Physics 2
