Fix Java Compile Error: "The system cannot find the path specified.
  • Context: Java
  • Thread starter Thread starter GiTS
    Java
The discussion addresses a Java compile error encountered when executing the command "C:\jdk6\bin\javac HelloWorldApp.java". The user is utilizing the JDK version jdk-6u6-windows-i586-p-iftw. The error message "The system cannot find the path specified" indicates a misconfiguration in the file path. To resolve this, users should ensure that the correct path to the Java compiler is set in the system's environment variables or use the correct syntax for directory separators.
  • Understanding of Java Development Kit (JDK) installation
  • Familiarity with command line operations in Windows
  • Knowledge of environment variable configuration in Windows
  • Basic understanding of file path syntax in programming
  • Configure system environment variables for Java JDK
  • Learn about using the command line for Java compilation
  • Explore Java file path conventions and syntax
  • Review troubleshooting techniques for Java compilation errors
Java developers, students learning Java programming, and anyone troubleshooting Java compilation issues on Windows systems.
GiTS
My problem is the first one listed here http://java.sun.com/docs/books/tutorial/getStarted/problems/index.html
But when I type C:\jdk6\bin\javac HelloWorldApp.java I get the message "The system cannot find the path specified."
Both the compiler and HelloWorldApp.java file are in C:/ folder. I'm using the jdk-6u6-windows-i586-p-iftw compiler.
What am I doing wrong?
Technology news on Phys.org
If they are in the C:\ folder give the command
C:\javac HelloWorldApp.java
or add the search path of javac to your path
If you put "\" between directories, you get a compile error. Instead of this sign you should put "\\" or "/". This is something that I remember from my cs courses. You should tyr this, but it might not solve your problem.
12K
