Photon Pairs - Can photons travel in pairs?
  • Context: Graduate
  • Thread starter Thread starter Buckeye
    Photon Photons Travel
The discussion revolves around the concept of whether photons can travel in pairs, particularly in the context of unpolarized light and its interaction with polarizing crystals. Participants explore the implications of photon polarization, statistical mixtures, and the nature of two-photon states.
  • Some participants question whether unpolarized photons can be thought of as traveling in pairs or a pair-like fashion before interacting with polarizers.
  • One analogy compares unpolarized photons to red and green balls, suggesting that they exist in a statistical mixture rather than as pairs.
  • It is noted that while usual light has a small amount of two-photon states, these states can exist and are observed under specific conditions.
  • Concerns are raised about the applicability of the red-green analogy to chirality and symmetry in quantum systems.
  • Participants discuss the nature of two-photon states, with some questioning if they imply entanglement.
  • There is mention of the photon number distribution in classical light, with distinctions made between Poissonian statistics for laser light and Bose-Einstein statistics for thermal light.
  • One participant highlights the phenomenon of photon bunching in thermal light, which leads to more coincidences than expected, but emphasizes that this does not imply that unpolarized light requires photons to travel in pairs.
Participants express differing views on the nature of unpolarized photons and their potential to travel in pairs. While some agree on the statistical nature of unpolarized light, others challenge the analogies used and the implications of photon bunching, indicating that the discussion remains unresolved.
Limitations include the dependence on definitions of photon states, the complexity of statistical distributions in different light sources, and the unresolved nature of how these concepts apply to the idea of photons traveling in pairs.
Buckeye
Light can be left or right polarized (circularly or elliptically). This is achieved by passing unpolarized light through various polarizing crystals which are optically active (ie chiral).
My paired questions are:
1. When we consider the photons before they strike the polarizers, can we think of those unpolarized photons as traveling in pairs or a pair-like fashion?
2. If they can not travel as pairs, then what evidence contradicts this possibility?
Why would you consider that ? Imagine that I have a bag with red balls and green balls, and then I pass them through a machine that let's the red balls pass, and takes away the green balls. Do we consider that balls come in "red-green" pairs ?
At first sight, quantum systems are different, but because you talk about *unpolarized* photons, we have to assume that they appear in a 50-50 statistical mixture, in which case the red-green ball analogy is applicable.
That said, they CAN travel in pairs: in 2-photon states. But usual light has only a very small amount of those.
If you would use a polarizing beam splitter, then you should find high coincidence rates if they came in pairs, which is not observed with usual unpolarized light (but IS observed in special situations when 2-photon states are produced).
I'm not sure the red-green filter system applies when we deal with symmetry based on chirality, which is, if memory serves me right, identical with parity and helicity. Am I thinking wrong?
Am fussy on 2-photo states. Is that entanglement?
Please point me toward a book or paper on the results of polarizing beam splitter results. Thanks!
Wiki is your friend !
Concerning polarizing beam splitters:
http://en.wikipedia.org/wiki/Polarizer
Just a random article concerning the observation of 2-photon states and the use of beam splitters (I just did a search and came up with this one, there are many):
http://prola.aps.org/abstract/PRA/v64/i4/e041803
or
http://scitation.aip.org/getabs/servlet/GetabsServlet?prog=normal&id=AJPIAS000070000003000260000001&idtype=cvips&gifs=yes
A 2-photon state is something else than two entangled photons. In fact, two entangled photons is rather the superposition of at least 2 different 2-photon states.
You should see a 2-photon state rather as similar to a 2-particle state: there are two particles present. In most classical optics, things happen "one photon at a time". That's why one can consider the "quantum wave function" of a single photon to be equivalent to the classical electromagnetic field (it's not the *same* though).
That's why, if you analyse classical light, you will get few coincidences: you will normally detect "one photon at a time", and the only reason why you sometimes get two of them is due to the dead-time of your detectors and the Poissonian distribution of the "single photons". In fact, this is not entirely correct: the full quantum-mechanical description of an intense classical beam is best described not by single-photon states, but by coherent states, which are superpositions of 1-photon, 2-photon, 3-photon ... states. But for not-too-intense beams, the 1-photon state is dominant.
However, by some interactions, like parametric down conversion, it is possible to turn 1-photon states into 2-photon states, and this light doesn't behave classically at all - or at least, has the potential of showing non-classical correlations and effects. They are at the core of the entire business of quantum optics.
You have to be very careful here. These statements are wrong for most cases. The photon number distribution is only Poissonian for laser light. Usual light from a bulb or from the sun is thermal light and the photon number distribution follows Bose-Einstein statistics. The distribution only gets Poissonian again if you sample time intervals, which are large compared to the coherence time of the light source. From a QM point of view, the 0-photon state is dominant for thermal light.
If you do coincidence counting with thermal light, you will also notice, that there are more coincidences than expected. Thermal light has a certain tendency for photons to arrive in pairs, called photon bunching, which was first demonstrated in the famous papers of Hanbury Brown and Twiss (R. Hanbury Brown and R. Q. Twiss (1956). "A Test of a New Type of Stellar Interferometer on Sirius". Nature 178: 1046-1048 or R. Hanbury Brown and R. Q. Twiss (1957). "Interferometry of the intensity fluctuations in light. I. Basic theory: the correlation between photons in coherent beams of radiation". Proc of the Royal Society of London A 242: 300-324).
However, it should be emphasized, that there is no connection between photon bunching and linearly or unpolarized light. Unpolarized light does not require photons to travel in pairs.
Correct. I over-simplified too much.
Thanks!
How can we be sure that our detectors have truly detected individual photons if the photons used to calibrate the detectors have actually measured bunched pairs?
I am not quite sure, what you are pointing at. Just to ensure that we mean the same: photon bunching is a statistical phenomenon meaning that the expectation value of consecutive photon detection for short time intervals is higher than a model of statistically independent photon emission would predict. It does not mean that there are always two photons arriving at the detector.
Now let us have a look at certain photodetectors. Most of them produce some current, which is proportional to the intensity of the incident light. These detectors are usually used for large intensities. Single photon counting is out of the scope of these detectors anyway due to reasons of detector noise.
Detectors, which are able to detect single photons, are for example single photon detection avalanche photo diodes, which usually have a sufficiently small dark count rate and can detect even single photons. The problem is, that such detectors usually have a long dead time, so that one does not know, how many photons exactly arrived at once or a short time after the first photon. Now the trick is to split the beam and use two (or even more) photo diodes. If there are several photons, there will be some coincidence counts, which means, that both diodes will detect a photon at the same time (or short intervals). If there is really just one photon, there won't be any coincidence counts as the photon does not split.
By the way photon bunching is measured in the same way. The rate of coincidence counts is then higher than expected. These measurements are a bit more tricky as thermal light usually has a very short coherence time. The best photo diodes offer a temporal resolution of about 50 ps (with terrible quantum efficiency - better quantum efficiency gives a temporal resolution of about 500 ps), which is far from what would be needed to characterize sunlight and in most cases still too slow to characterize light from a semiconductor laser below threshold.
  • · Replies 58 ·
  • · Replies 0 ·
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 80 ·
9K
