Projectiles, spin, momentum, and range
The discussion revolves around the dynamics of a spherical projectile, specifically a 6mm pellet, fired horizontally with backspin. Participants explore the effects of spin on range, momentum, and the role of air resistance in determining the projectile's behavior at different velocities (250 fps vs. 500 fps). The conversation touches on theoretical aspects of projectile motion, aerodynamics, and fluid mechanics.
  • Some participants propose that backspin affects the pressure above the pellet, potentially counteracting gravity, while others argue that the primary purpose of spin is to enhance aerodynamic stability.
  • One participant suggests that neglecting air resistance simplifies the problem, allowing for straightforward calculations of time in the air and distance traveled based on muzzle velocity.
  • Another participant emphasizes the importance of air resistance, noting its non-linear nature and its significant impact on projectile motion.
  • There is a discussion about the lift generated by backspin, with some participants noting that the shape of the projectile and turbulent flows are critical factors in determining the lift effect.
  • One participant mentions that a perfect sphere would not generate lift, suggesting that empirical measurement may be necessary to understand the effects accurately.
  • Atmospheric conditions are highlighted as an important variable, with a specific mention of how conditions on Mars would alter the pellet's behavior compared to Earth.
Participants express differing views on the effects of backspin and air resistance, with no consensus reached on the precise dynamics involved. The discussion remains unresolved regarding the overall impact of these factors on the projectile's range.
The discussion includes assumptions about the projectile's shape, the nature of air resistance, and the influence of environmental conditions, which may not be fully explored or defined.
MattK
[SOLVED] Projectiles, spin, momentum, and range
Greetings. I am simply seeking information regarding the matters of the subject line.
Here is the situation:
A spherical projectile (6mm pellet) is fired out of a device at say 400 feet per second. It is fired out level to the ground (as if you are aiming a gun at a target - no real trajectory above horizontal).
To complicate things, a backspin is placed on the projectile inside of the barrel... the backspin causing a change in pressure above the pellet as it spins, thus to some degree counteracting gravity.
So if I were to speculate on the different ranges (distances the pellet would travel before hitting the ground) of a pellet fired at 250 feet per second vs. one fired at 500 fps, what all would come into play?
Thanks for any input.
The spinning causes no pressure effects -- if it were to, it would affect the top and bottom equally. Bullets are spun by a rifle barrel not to "counteract gravity," but to make them aerodynamically stable. The spinning bullet takes advantage of gyroscopic rigidity in space, and resists its direction being changed by moving air.
If you neglect air resistance (which is non-linear -- it's quadratic in the velocity), the problem is simple. The bullet falls vertically at the same acceleration (9.8 m/s2) as anything else. You can calculate how long the bullet's in the air just as a function of how high above the ground it is fired. You can calculate the distance covered by multiplying its muzzle velocity by that time.
- Warren
Its not rifling I am talking about. The pellets are sperical, and they have actual backspin on them. The backspin allows the air to move faster over the top surface of the BB, and slower over the bottom surface.. thus producing lift as seen in an airplane wing.
But air resistance is in fact what I am interested in. :) Thanks.
The lift effect of spinning has a lot to do with the exact shape of the ball and turbulent flows around it -- this is part of the reason baseballs have seams IIRC. I think it's one of those really complicated fluid mechanics problems... I certainly don't know of any simple formulae or approximation for the effect.
Air resistance can be roughly given by the drag force
F = C*rho*v^2*A/2
where A is the area of the projectile (pi*r^2 here), rho is the density of the fluid (air), and C is the drag coefficient -- probably about 0.5.
Yeah, the amount of life generated by the backspin will depend upon the specifics of the surface of the projectile. It seems that technically, if the projectile were a perfect sphere, it would not move the air around it at all, and would not generate any lift. In general, I wouldn't try to calculate the effect from first principles -- I would just measure it.
- Warren
As has been stated, the specific aerodynamics of the pellet is one factor that must be considered. Atmospheric conditions are also important. For example; on Mars, the pellet would actually fall faster than it would without backspin, and forward spin would cause it to climb.
23K
  • · Replies 112 ·
23K
10K
  • · Replies 38 ·
  • · Replies 19 ·
44K
