Thread Closed
Special Theory of Relativity
Share Thread Thread Tools
May21-08, 02:35 AM   #1
a.a
A carpenter on a space statopn has constructed a 30 degress ramp. A rocket moves past the space station with a relative speed f 0.730c in a direction parallel to the horizontal. What does a person above the ocker measure for the angle of the ramp?
2. Relevant equations
sine and cosine relations
L(m) = L(s)sqrt. 1-v^2/c^2
3. The attempt at a solution
I havent been able to simplify far enough to get an angle. I'm not to sure about which length is L(m) or L(s) and I assumed that the angle that the rocker would measure would be from L(m) and H(m), but i arrive at a different answer. The answer is supposed to be 40.2 degrees.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
May21-08, 02:45 AM   #2
Recognitions:
Homework Helper Homework Help
can you show the work you did in detail. Otherwise you wont get help.
May21-08, 02:45 AM   #3
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Edit: Sorry MG, I didn't see your post there.
May21-08, 06:55 PM   #4
a.a
does the heigh always stay the same regargless of weather it is starionaty or moveing?
Umm.. so i took another look and i decided to use trig ratios and solve for moveing length and let relativeistic length be root. 3
May22-08, 02:29 AM   #5
Recognitions:
Quote by a.a View Post
That is correct, since motion in perpendicular directions is independent, Lorentz contractions are only observed in the direction in which the observer is travelling. So in this case the observed height is equal to the proper height, but the base of the ramp is observed to be Lorentz contracted.
Thread Closed
Thread Tools
Similar Threads for: Special Theory of Relativity
Thread Forum Replies
Special Theory of Relativity Introductory Physics Homework 3
=Special Theory Of Relativity= Special & General Relativity 40
Relativity : the Special and General Theory Special & General Relativity 3
Einstein's theory of Special Relativity Special & General Relativity 8
Is The Theory Of Special Relativity Wrong? General Physics 18
