Thread Closed
manufacture of bromine
Share Thread Thread Tools
May21-08, 05:27 AM   #1
Bromine is obtained from the sodium bromide dissolved in sea water by:
I passing chlorine into sea water at pH 3.5
II blowing out the bromine with air and absorbing it in aqueous sodium carbonate
III acidifying the solution and distilling out the bromine.
(i) Write an equation for step I.
(ii) Step II produces a solution of sodium bromate(V), NaBrO3 in the molar ratio 1:5.
Construct an equation for the formation of the bromine in step III.
3. The attempt at a solution
(i) Cl2 + NaBr ----> NaCl + Br2
(ii) i have no idea how to interpret the information provided in this part. how can the mole ratio help me?
thnks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
May21-08, 06:53 AM   #2
Admin
Google disproportionation.
Borek
http://www.chembuddy.com
http://www.ph-meter.info
May21-08, 07:44 AM   #3
i didn't think of the disproportionation of bromine into bromide Br- and bromate BrO3-.
thnks
but how does either of the products give bromine upon acidification?
is it a similar reaction as acid + carbonate?
May21-08, 08:56 AM   #4
Admin
I would call it "pH dependent equilbrium".
May21-08, 09:22 AM   #5
i tried googling pH dependent equilibrium but i couldn't find something specific to the bromine extraction reaction.
sodium carbonate is alkaline. the pH would be around 9-10. acidifying the solution would decrease the pH...
i'm lost...
May21-08, 09:35 AM   #6
Admin
You are close. Just write balanced reaction equation Br2 + OH- and you will see that it is pH dependent. LeChetelier's priniciple is enough to explain what is going on.
Borek
May21-08, 11:19 AM   #7
3Br2 + 6OH- ----> 5Br- + BrO3- + 3H2O
ahhh..... now i get why the ratio is 1:5....
is the reaction reversible?
if this is the case, as you add H+, the concentration of OH- decrease. according to LCP the backward reaction is favoured, producing more Br2
Thread Closed
Thread Tools
Similar Threads for: manufacture of bromine
Thread Forum Replies
Preperation of bromine gas Biology, Chemistry & Other Homework 2
how advances in matrerials technology have affected design and manufacture of bicycle Engineering, Comp Sci, & Technology Homework 0
how to manufacture gear? Engineering, Comp Sci, & Technology Homework 1
Bromine Chemistry 2
Manufacture of nitric acid Chemistry 7
