The Physics of Sound: Why No Music Beyond the Door?
  • Context: High School
  • Thread starter Thread starter AnthreX
    Music Physics Sound
The discussion revolves around the physics of sound, specifically addressing why only bass sounds are heard when music is played behind a closed door. Participants explore concepts related to sound waves, frequency, and the interaction of sound with physical barriers.
  • One participant notes that bass sounds, being long waves, pass through obstructions more easily than higher frequency sounds.
  • Another participant seeks clarification on whether long waves correspond to lower frequencies.
  • A participant explains that sound waves of different wavelengths travel at the same speed in a constant environment, but their frequencies differ inversely with wavelength.
  • One participant challenges a previous claim about sound wave behavior, asserting that the speed of sound remains constant regardless of wavelength and correcting the misunderstanding regarding octaves.
  • Another participant acknowledges a mistake regarding the definition of octaves but expresses confusion about the explanation of sound wave speed.
Participants express differing views on the relationship between wavelength, frequency, and sound speed. While there is some agreement on the behavior of bass sounds, the discussion contains unresolved disagreements about the technical explanations provided.
There are limitations in the clarity of explanations regarding sound wave behavior and the definition of octaves, which may affect participants' understanding of the concepts discussed.
AnthreX
i was in my room listening to rock musics with speakers and the door closed
and i went out of the room closing the door behind me and in about 7~8m away from the room i didnt hear any voices coming out of the door just the bass beats ( drums ),
why is that ?
( the door is just a wooden door )
the wall is concrete
speakers were facing the door
Bass is a long wave, and passes through obstructions more easily.
Sounds good to me. :eek:
Couldn't resist.
long wave means lower frequency ?? :confused:
If the waves are moving at the same speed (like soundwaevs crossibng a room), yes. Two waves cross a room, one has length L, the other's length is 1/2L. The one that is twice as long will take twice as much time to pass at the same speed. So it will have frequency 1/2 that of the other wave, making it 1 ochtave lower.
None of this is true... If a sound wave has wavelength L and another has wavelength L/2 in the same room then they still will move at the same speed. The one with L/2 will have twice as high of a frequency. speed of sound = wavelength times frequency... and the speed of sound is pretty much constant in a constant environment nomatter what the wavelength. But the reason why you only hear bass has already been said, lower frequency (longer wavelenghts) can pass through objects better. One more this... Ochtaves are not based off doubling a frequency, and ochtave is a multiple of the base frequency of that note. If 'C' is 356, then the ochtaves of C are n*356 where n is 1,2,3...
anthrex,
Dude apparently did not understand my post. I hope that you did, but I want to make sure. This part:
TheDude710 said:
None of this is true... If a sound wave has wavelength L and another has wavelength L/2 in the same room then they still will move at the same speed. ... and the speed of sound is pretty much constant in a constant environment nomatter what the wavelength.
is exactly the same as what I said here:
What I'm saying is that the wave that is twice as long will take twice as much time to pass a stationary point (like your ear drum, for example) specifically because it is traveling at the same speed as the shorter wave.
As for this:
You can research it yourself here or any number of music theory sources.
Sorry man, I was incorrect on Ochtaves but the way you explained the speed thing was unclear.
  • · Replies 31 ·
  • · Replies 22 ·
13K
