Why does the colour black heat faster than white?
  • Thread starter Thread starter BryceG
    Colour Heat
The discussion revolves around various physics questions posed by a Year 11 student, including why the color black heats faster than white, the formation of rainbows, and the properties of diamonds, among others. The subject area encompasses concepts from thermodynamics, optics, and classical mechanics.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants explore the reasons behind the heating properties of colors, the formation of rainbows through refraction, and the behavior of light in different materials. Questions about the nature of black holes and the principles of Newton's laws are also raised.
Some participants provide explanations and insights into the questions raised, particularly regarding the absorption of light by different colors and the refractive properties of materials. There is an ongoing exploration of the concepts without a definitive consensus on all points, particularly regarding the cooling rates of water and the nature of light speed in different media.
The original poster emphasizes the requirement to ask questions for their assignment, indicating a structured approach to their learning process. Some responses include references to external sources for further information.
BryceG
I am required to ask questions as part of my physics assignment at school. I am in Yr 11 physics btw. If some people can please answer these that would be great. Before anyone says i should know some of these or that i could find out by surfing the internet, i know that i canm but none the less i would stil be required to ask questions to a person/s about physics.
Thanks in advance.
1)Why does the colour black heat faster than white?
2)How and why are rainbows formed?
3)Why does a diamond sparkle?
4)why does water cool down so much slower than it heats up?
5)What are Newton's three laws?
6)Why can a person lie on a bed of nails and not be injured?
7)What is a Black hole?
8)When you look into water why do objects appear to be in a different spot than if you were looking from underwater?
9)Is there any truth in the statement "Red is the fastest color"?
10)What are potential and kinetic energy?
Okay, you were required to ask questions. Are you required to get any answers?
yes, i wouldn't bother posting them if u didnt want answers
Black absorbs all colors of light, white reflects them: light is energy, i.e. heat.
Different colors of light are refracted at different angles by drops of water in the air. In order to see the same color, the light must go at the same angle from the sun to your eye which is why a rainbow is a circular arc.
Same answer, really. Different colors of light are refracted at different angles. Diamond has a very high refractive index so it is much more apparent than with glass or crystal.
I didn't know it did! If you take two equal glasses of water, one at, say, 10 degrees above room temperature, the other at 10 degrees below room temperature, they should go to room temperature in the same time.
I. Every object in a state of uniform motion tends to remain in that state of motion unless an external force is applied to it.
II. The relationship between an object's mass m, its acceleration a, and the applied force F is F = ma. Acceleration and force are vectors (as indicated by their symbols being displayed in slant bold font); in this law the direction of the force vector is the same as the direction of the acceleration vector.
III. For every action there is an equal and opposite reaction.
I got those from http://csep10.phys.utk.edu/astr161/lect/history/Newton3laws.html and I got that url by going to "google.com" and entering "Newton's Laws". If you are learning to use the internet to answer physics questions, I recommend you become familiar with google!
I, personally, wouldn't want to do it but if there are enough nails, the weight of your body is spread across all the nails so there is only a little force on each one. Think of it this way: if you put the nails right up against one another, you would have a flat metal surface!
A mass so concentrated (we are talking about the mass of the sun squeezed into a few cubic millimeters here) that its "escape velocity" is greater than the speed of light.
Refraction again. When the light wave passes from the water to the air, on its way to your eye, the change in speed causes it to bend at an angle. Of course, your eye and brain only know the final angle of the light so you "see" the object as if it were on that line.
I don't think there is any sense in it!
I'll just add a few notes to Halls' answers.
That especially high refractive index, coupled with the way the diamond is cut, cause much total internal reflection within the diamond: the light bounces around inside, until it finds a straight path out. (In ordinary glass, the light would leak out the sides instead of reflecting back out where it came in.)
Think of it this way: Would a person want to lie on a bed of nails with only one nail?
Only in the sense that the refractive index of many transparent substances (like glass or water) depends on the wavelength. And red light generally has a lower index of refraction than blue light. Which means that red light does go faster in glass or water.
  • · Replies 19 ·
  • · Replies 32 ·
12K
