Is the Electric Field Zero Inside an Infinitely Long Cylinder?
The electric field inside an infinitely long cylinder with a uniform charge density is not zero. In the discussed scenario, a cylinder with a radius of 4.0 cm and a charge density of 200 nC/m³ produces an electric field of 0.47 kN/C at a distance of 3.9 cm from its axis. The calculation utilizes Gauss's law, which accounts for the charge distribution within the cylinder rather than assuming charges only reside on the surface. The correct application of Gauss's law confirms that the electric field is determined by the enclosed charge within the Gaussian surface.
  • Understanding of Gauss's Law
  • Familiarity with electric fields and charge distributions
  • Knowledge of uniform charge density concepts
  • Basic calculus for electric field calculations
  • Study the application of Gauss's Law in various geometries
  • Learn about electric fields in conductors versus insulators
  • Explore the concept of charge density and its effects on electric fields
  • Investigate the implications of electric fields in real-world applications, such as capacitors
Physics students, electrical engineers, and anyone interested in electromagnetism and electric field calculations.
kasse
[SOLVED] Electric field around cylinder
An infinitely long cylinder with r = 4.0 cm has a uniform charge density of 200 nC/m^3. What is the electric field 3.9 cm away from the axis?
The first thing I thought is that the field has got to be 0 since all the charge will be on the surface of the cylinder. But maybe this applies only to spheres?
Anyway, I calculated the charge per meter: 1.01 nC/m. Then I used Gauss law:
Q/l = e0E*2*pi*r, which yields
E = (Q/l)/(2*pi*r) = 0.47 kN/C
Is this correct?
Hi kasse,
About the charges being on the surface: If this was a conductor (so that the charges could move) then the charges would be on the surface. However, here the charges are uniformly spread throughout the cylinder and cannot move.
When you draw your Gaussian surface at 3.9 cm from the axis, you have to take into account that some of the charges are outside the Gaussian surface and some are inside; only those charges that are enclosed in the Gaussian surface will appear in Gauss's law.
Well explained. Thanks!
  • · Replies 36 ·
  • · Replies 16 ·
  • · Replies 26 ·
