Ampere's law vs. Biot-Savart law
The discussion centers on the differences between Ampere's law and the Biot-Savart law, exploring their applications, derivations, and the contexts in which each law is most effectively utilized. The scope includes theoretical considerations and practical applications in electromagnetism.
  • Some participants propose that Ampere's law is a special case applicable primarily to situations with symmetry, such as straight wires, sheets of current, and solenoids.
  • Others argue that the Biot-Savart law is more fundamental and can be used in a broader range of scenarios, suggesting that Ampere's law can be derived from it but is limited to specific conditions.
  • A participant questions a calculation related to the Biot-Savart law, suggesting that a "pi" term should not be present in the answer, indicating uncertainty about the correctness of the calculation presented in an external link.
  • Another participant notes that Ampere's law may not provide accurate results for short wires or solenoids, as it assumes a nearly constant magnetic field and does not account for the curvature of field lines at the ends of the conductors.
Participants express differing views on the applicability and fundamental nature of Ampere's law versus the Biot-Savart law, indicating that the discussion remains unresolved with multiple competing perspectives.
Limitations include the dependence on the symmetry of the current configurations and the assumptions made in applying Ampere's law. There are unresolved questions regarding the correctness of specific calculations related to the Biot-Savart law.
kasse
What's the difference? Is Ampere's law a special case (when the conductor carrying the current is a straight wire?)
Biot-Savart law is the more important and fundamental one. Ampere's law can be derived from it but can only be used in some very specific situations, but not only in straight wire cases. It can be applied to sheets of current, solenoids, etc.
OK, thanks. Btw, isn't the last calculation wrong here: http://planetphysics.org/encyclopedia/QuarterLoopExampleOfBiotSavartLaw.html
There should be no "pi" in the answer if I'm right.
Ampere's law is usually only applied to problems that have certain symmetry.
For example, a straight wire is symmetric about it's center axis, a sheet is symmetric, a solenoid is symmetric, etc...
Some arbitrary wire is not symmetric however and Ampere's law can generally not be used there.
Also if you only have a short solenoid or wire for example (a short length in relation to it's radius) then Ampere's law does not give a very accurate answer either, because it ignores the fact that the magnetic field lines curve away from the wire at the ends; it assumes the magnetic field is nearly constant.About the link, if the calculation up until the integral is correct then yes, the pi should cancel indeed. I haven't checked what they did before that though, but I think it's correct (so the pi is wrong).
  • · Replies 16 ·
  • · Replies 21 ·
