How Much Does It Cost to Run Household Appliances?
  • Thread starter Thread starter Dx
    Electric
The discussion focuses on calculating the cost of running household appliances, specifically a portable CD player powered by a 9V battery and an air conditioning unit alongside lightbulbs. The cost of energy for the battery is determined to be $8.98 per kWh, calculated using the formula Cost = Power x Time x Cost per unit. Additionally, the total contribution of the AC unit and ten 60W lightbulbs to the monthly electric bill is calculated to be $11,760, based on their combined power consumption and the electricity rate of $8.0 per kWh.
  • Understanding of Ohm's Law and basic electrical formulas
  • Knowledge of power calculations in watts (W) and kilowatts (kW)
  • Familiarity with energy cost calculations in dollars per kilowatt-hour (kWh)
  • Ability to convert units between watts, kilowatts, and hours
  • Learn how to calculate energy costs for various household appliances
  • Research the impact of energy efficiency on electricity bills
  • Explore the use of smart meters for monitoring household energy consumption
  • Understand the principles of energy conservation in home appliances
Homeowners, energy auditors, and anyone interested in understanding and optimizing household energy consumption and costs.
Dx
I have two questions that i need help with, please?
1) A 9V battery costs $1.49 and will run a portable CD player for 6 hours. Suppose the battery supplies a current of 25mA to the player. What is the cost of energy in dollars per kWh?
I started out using ohms law but am lost for there. How do i set up this for a formula i can solve for dollars per kWh?
2) The monthly(30days) electric bill included the cost of running a AC unit for 2hr/day at 5000W, and a series connection of ten 60W lightbulbs for 5hr/day. How much did these items contribute to the cost of the monthly electric bill if electricity costs 8.0 per kWh?
1st i added the ten 60W = 600W. Next, i took (2hr/d)*(30d) = 60h. Also took (5hr/d)*(30d)=150h, i added 5KW + 600W = 5.6KW for total wattage. I plugged in a formula like so (5.6k)*(2.1k)* ?
How do i find the daily cost of electricity, my answer is 2.86x10^-1, i got that from (8/kWh) / 4weeks = ans. Then ans / 7 days = 2.86 x 10^-1
But i am not right, what am i doing wrong, can you help me solve this please?
This problem is pretty easy, so I don't want to give too much away. Here are the overall steps:
1. Calculate the power delivered to the CD player. You have all the info for that.
2. Calculate the total energy delivered to the CD player. You were given one piece of info for that, and you will calculate the other piece in Step 1.
3. Calculate the cost for that energy. You were given one piece of info for that, and you will calculate the other piece in Step 2.
Give it a shot.
1st i added the ten 60W=6KW.
I assume you meant to say 60W+[/color]6kW. That's fine, just don't forget to convert kW-->103W.
Next, i took (2hr/d)*(30d) = 60h. Also took (5hr/d)*(30d)=1.5Kh,
You made a mistake. 1.5Kh=1500h, which is wrong.
I am having trouble following you from here. Please correct the above mistake, check your math carefully, and come back if you need more help.
1) To calculate the cost of energy in dollars per kWh, we can use the formula: Cost = Power x Time x Cost per unit. In this case, the power is 25mA (0.025A), the time is 6 hours, and the cost per unit is $1.49. So, the cost of energy for the battery is: Cost = 0.025A x 6h x $1.49 = $0.2245.
To find the cost per kWh, we need to convert the units to kW and hours. 1 kWh is equal to 1000 watts for 1 hour. So, we can divide the cost by the number of watts (25mA or 0.025A) and multiply it by 1000 to get the cost per kWh.
Cost per kWh = ($0.2245 / 0.025A) x 1000 = $8.98.
Therefore, the cost of energy for the battery is $8.98 per kWh.
2) To find the daily cost of electricity, we can use the formula: Cost = Power x Time x Cost per unit. In this case, the power is 5.6kW, the time is 7 hours (2 hours for AC and 5 hours for lightbulbs), and the cost per unit is $8.0 per kWh. So, the cost of electricity for one day is: Cost = 5.6kW x 7h x $8.0/kWh = $392.
To find the monthly cost, we can multiply the daily cost by the number of days in a month (30 days).
Monthly cost = $392 x 30 days = $11,760.
Therefore, the items contributed $11,760 to the monthly electric bill.
  • · Replies 30 ·
