Solve 1/a + 1/b + 1/c = 1: Find All Integer Solutions
  • Context: Undergrad
  • Thread starter Thread starter xax
The discussion focuses on finding all integer solutions to the equation 1/a + 1/b + 1/c = 1. Participants explore various approaches, assumptions, and potential solutions, including both positive and negative integers.
  • Homework-related
  • One participant seeks to find all possible integer solutions for the equation.
  • Another participant requests that homework questions be posted in the appropriate forum.
  • A participant shares their progress, mentioning a method involving equations for b and c in terms of a, but expresses difficulty due to the number of possibilities.
  • It is suggested to assume a ≤ b ≤ c for simplification, with specific cases explored for a = 1, 2, and 3.
  • Some participants note that the original problem allows for negative integers, leading to additional families of solutions.
  • Examples of solutions involving negative integers are proposed, such as a = -b and c being arbitrarily large.
  • One participant claims to have found three solutions under certain conditions and questions if more exist.
  • Discussion arises about the implications of having one or more negative integers in the solutions.
  • Another participant asserts that if two values are negative, the sum of the reciprocals cannot equal 1.
  • Specific integer solutions are listed, and a new question is posed regarding the equation 1/a + 1/b + 1/c = 7, with a claim that there are zero solutions.
Participants express differing views on the nature of solutions, particularly regarding the inclusion of negative integers. While some agree on the existence of specific solutions, others question the completeness of the findings, leading to unresolved discussions about the total number of solutions.
Some assumptions about the positivity of integers are challenged, and the implications of allowing negative integers are not fully resolved. The discussion includes various mathematical approaches and reasoning that may not cover all possible cases.
xax
Need to find all the posible solutions (a,b,c) for 1/a + 1/b + 1/c = 1, a,b,c integers.
xax, please show your work, and post your homework questions in the correct forum.
D H, I thought I was in the right forum. What I did so far: b+c = (a-1)*t and b*c = a*t and (c-1)*(b-1) = t+1. I'm stuck because I get too many posibilities.
You can start by assuming, for the time being, that [itex]a\le b\le c[/itex] -- you can rearrange the terms later if you need to.
If a = 1 then the sum is too large, so [itex]2\le a\le b\le c.[/itex] If a = 2, [itex]1/b+1/c=1/2[/itex] so clearly b needs to be no more than 4 (to get 1/4 + 1/4 = 1/2). Check the cases of b = 3 and b = 4.
If a = 3 then b and c need to be small to make the sum 1, so check cases similarly.
Finally, rearrange the solutions you have as needed (so a need not be the smallest).
That is true only if a, b, c are restricted to the positive integers. The OP just said integers.
True, I missed that. There is one family of solutions which includes negative numbers.
for example if a=-b an c is arbitrary big or similar we have an approximate solution in integers to your equation.
or simply a=-b and c=1 b=-c and a=1 a=-c and b=1
Thanks a lot to all of you and expecialy to CRGreathouse. I've proven that a<=3, b<=4 and found all the solutions(there are 3 in total).
Edit: If one of them is negative the solution is (t,1,-t). Do you think there are more?
If two are negative you have 1 - 1/a - 1/b < 1. If three are negative you have -1/a - 1/b - 1/c < 0.
Yes CRGreathouse, that's why I said that only one can be negative. My question was are there other solutions when one number is negative besides (t,1,-t)?
If exactly one value is negative and another value is 1, the values are (1, v, -v). Otherwise, the sum of the reciprocals of the positive values is at most 1, so not a solution (since the negative will lower the result).
try to prove if there is finite amount of solutions
This is easy:
2, 3, 6
2, 6, 3
3, 2, 6
3, 6, 2
6, 2, 3
6, 3, 2
6 solutions..
1/2 + 1/3 + 1/6 = 1.
Then i got a new question.
1/a + 1/b + 1/c = 7.
If a, b, c, are integers, how many solutions are there?
Zero! Because 1/a, 1/b and 1/c are all <=1. Therefore their sum is <=3.
I thought of it as well..
Just needed a second opinion.
Thanks! :)
  • · Replies 25 ·
  • · Replies 33 ·
  • · Replies 17 ·
