Infinite Group Has Infinite Subgroups
  • Thread starter Thread starter e(ho0n3
    Group Infinite
The discussion revolves around the properties of infinite groups and their subgroups, specifically addressing the assertion that an infinite group must have an infinite number of subgroups. The original poster presents examples of infinite groups, such as the additive group of integers and the multiplicative group of positive reals, while attempting to construct a proof by contradiction.
  • Participants explore the implications of elements having infinite order and the generation of subgroups from these elements. There is discussion about the uniqueness of generated subgroups and the conditions under which they may be distinct. Questions arise regarding the implications of terminating processes in subgroup generation and the relationship between subgroup properties and the finiteness of the group.
The discussion is ongoing, with participants providing insights and clarifications on the nature of subgroup generation in infinite groups. Some guidance has been offered regarding the contradiction that arises if the process of finding distinct subgroups were to terminate, although there remains some confusion about the implications of this termination.
Participants note that the original proof attempts may not hold universally across all groups, highlighting the need for careful consideration of group properties and definitions. There is also mention of specific groups, such as Z_p, that challenge the assumptions made in earlier posts.
e(ho0n3
[SOLVED] Infinite Group Has Infinite Subgroups
Prove that an infinite group must have an infinite number of subgroups.
The attempt at a solution
There are two infinite groups that I can think of: the additive group of integers Z and the multiplicative group of positive reals R+. Except for 0, all elements of Z have infinite order and <n>, n ≥ 0, is a unique subgroup of Z. The same seems to hold for R+. Hmm...
Let G = {e, a1, -a1, a2, -a2, ...} be an infinite additive group. I'm led to believe that <ai> ≠ <aj> if i ≠ j.
The following is a plausible proof by contradiction: Suppose <ai> = <aj>. That means <ai> is a subset of <aj>, so there is a positive integer m > 1 such that maj = ai, and <aj> is a subset of <ai> so there is a positive integer n > 1 such that nai = aj. This implies that mnai = maj = ai and since mn > 1, <ai> is finite which means that ai has finite order. So all I have to prove now is that ai has infinite order.
This is where I'm stuck. I need a little push.
If there exists x in G such that x has infinite order, consider the group generated by x^2, x^3, x^4, ... Containment one way is trivial, so if the groups aren't distinct, I'm sure you can find a contradiction to the fact that x has infinite order.
If |x| is finite for all x in G, pick x1, x2, x3, ... such that x2 is not contained in <x1>, etc. These are an infinite number of subgroups, and are obviously distinct since otherwise |G| is finite.
Right. This is what I did in my first post, essentially.
So I start by picking x1 in G. Then I find an x2 in G that is not in <x1>. Then I find an x3 in G that is not in <x2> and <x1>. Etc. And there is an infinite number of these. Sure they are distinct but how does that make |G| finite?
It doesn't make |G| finite. That's the point. You've found an infinite number of distinct subgroups. If the process terminated at some point, that would make |G| finite, a contradiction.
I messed up. I meant to ask why |G| is finite if the process terminates.
Because you can count the elements. Say it stops after n steps. Then you can't find an element of G not in <xi> for some i. But since |<xi>| is finite for each i, you have a finite sum of finite numbers, and you're done.
Right! I forgot that |<xi>| = |xi| which is finite. Thanks a lot.
This is a little late, but you might also notice that your first attempt was doomed to failure. To say <ai>=<aj> iff ai=aj only true in some groups (such as both of your examples). Consider Z_p for p prime. All non-identity elements generate the whole group. You might say that's because it's finite, but then consider Z_p x Z.
  • · Replies 17 ·
