Plug in time to find the acceleration
  • Thread starter Thread starter Jason03
    Acceleration Time
The problem involves calculating acceleration in a rotational motion context, specifically focusing on how to incorporate time into the calculations. The original poster is working with formulas related to tangential and normal acceleration.
  • Exploratory, Mathematical reasoning
  • The original poster attempts to use formulas for tangential and normal acceleration, initially expressing uncertainty about how to find angular speed at different times. Some participants question the correctness of the formulas used and the application of time in the calculations.
Some participants have provided guidance on the formulas and have shared calculations for specific time instances. There is an indication that the original poster has made progress in understanding the problem, but there are still areas of uncertainty regarding the calculations for other time intervals.
There is mention of specific values used in calculations, such as radius and angular acceleration, but the discussion does not clarify the overall setup or constraints of the problem. The original poster's approach appears to be influenced by the need to adhere to homework guidelines.
Jason03
Heres the problem I am working on...
http://img502.imageshack.us/img502/1613/rotut5.jpg
Im trying to figure how to plug in time to find the acceleration...
I found the first acceleration of 100mm/s^2...but I am not sure how to get the others...
I was using the formula
[tex]a_{t} = r\theta[/tex]
[tex]a_{n} = r\omega^2[/tex]
That first equation should be:
[tex]a_{t} = r\alpha[/tex]
How can you find the angular speed at each of those times?
at time = 0 I was able to do
[tex]a_{t} = r\omega = 9(.200)(.5) = .100 = 100mm/s^2[/tex]
and that is correct for the first answer...
but for the other times I wasnt sure...
ok I figured it out for time at 2...and its the same for each time...its just
[tex]a_{t} = r\alpha = (.200)(.5) = .100[/tex]
[tex]\omega = \omega_{o} + \alpha(t)[/tex]
[tex]\omega = .5 rad/s[/tex]
[tex]a_{n} = r\omega^2 = (.200)(.5)^2 = .050[/tex]
[tex]A = \sqrt{a_{t}^2+a_{n}^2} = 111.8 mm/s^2[/tex]
