Thread Closed
How does a loop of wire in a generator produce alternating current?
Share Thread Thread Tools
May27-08, 05:38 PM   #1
a.by creating current by rotating in an existing magnetic field?
b.by creating a varying magnetic field with its rotational kinetic energy
c.by rotating through areas of high and low electrical force
An electric field produces a magnetic field even when there is no wire to conduct a current provided which of the following is also true?
a.The electric field is between a pair of parallel metal plates.
b.The electric field changes in time but at each instant is the same at every location.
c.The electric field is changing as time passes.
d.The electric field is different from place to place.
e.The electric field does not change as time passes.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
May27-08, 10:49 PM   #2
It might help if you post some of your thoughts. For the first problem, consider the implications of Faraday's Law. For the second problem, consider Maxwell's extension to Ampere's Law (or Ampere's circuital law as it's named in this link): http://en.wikipedia.org/wiki/Maxwell%27s_equations
What's happening to the electric field E in this equation?
Thread Closed
Thread Tools
Similar Threads for: How does a loop of wire in a generator produce alternating current?
Thread Forum Replies
EASY Multiple concept questions- How does a loop of wire in a generator produce AC Introductory Physics Homework 0
alternating current versus direct current General Physics 18
Alternating Current vs Direct Current General Physics 17
Current in wire loop inside a solenoid... Introductory Physics Homework 7
Square loop carrying current near a wire Advanced Physics Homework 10
