Thread Closed
EASY Multiple concept questions- How does a loop of wire in a generator produce AC
Share Thread Thread Tools
May27-08, 05:51 PM   #1
How does a loop of wire in a generator produce alternating current?
a.by creating current by rotating in an existing magnetic field?
b.by creating a varying magnetic field with its rotational kinetic energy
c.by rotating through areas of high and low electrical force
An Electric Field produces a magnetic field even when there is no wire to conduct a current provided which of the following is also true?
b.The electric field changes in time but at each instant is the same at every location.
c.The electric field is changing as time passes.
d.The electric field is different from place to place.
2. Relevant equations
3. The attempt at a solution
for
First question, I concluded it to be B.
Second Question, From process of elimination, i said it was B also.
Correct me if I am wrong :x
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Thread Closed
Thread Tools
Similar Threads for: EASY Multiple concept questions- How does a loop of wire in a generator produce AC
Thread Forum Replies
How does a loop of wire in a generator produce alternating current? Introductory Physics Homework 1
Wire with a Loop in it Introductory Physics Homework 2
Electricity in wire (again) - concept question General Physics 10
Wire Loop in Equilibrium-Angle? Introductory Physics Homework 1
spring mass on wire on loop Introductory Physics Homework 2
