Non-Expert Q: Why Not Modify QM for Strings Theory?
  • Context: Graduate
  • Thread starter Thread starter mmzaj
The discussion revolves around the question of why physicists do not modify quantum mechanics (QM) to accommodate string theory, particularly in the context of achieving a four-dimensional framework while maintaining consistency with known quantum principles. Participants explore the implications of string theory's requirement for additional spacetime dimensions and the potential for new quantization processes.
  • One participant suggests that the need for additional dimensions in string theory arises from the quantization of the classical action of the string, questioning why a new quantization process that yields four dimensions has not been pursued.
  • Another participant acknowledges the idea as interesting but emphasizes that without a specific method for generalizing the quantization process, it remains speculative.
  • A different viewpoint states that string theory does not propose any modification of quantum mechanics and that altering the quantization method would fundamentally change the nature of string theory itself.
  • Some participants reference non-critical string theory and its potential applications in four dimensions, while noting that such theories may not describe a Lorentz invariant background.
  • One participant mentions past attempts by loop quantum gravity theorists to apply nonstandard quantization procedures to string theory, which were not well received due to issues with quantum anomalies.
  • Another participant argues that additional dimensions in string theory are beneficial, as a four-dimensional framework would be too simplistic to accommodate the interactions observed in the Standard Model of elementary particles.
Participants express a range of views on the feasibility and implications of modifying quantum mechanics for string theory. There is no consensus on whether such modifications are desirable or possible, and the discussion remains unresolved regarding the potential for new quantization processes.
Some participants highlight the limitations of the discussion, noting the broad nature of the initial question and the complexity involved in developing new quantization methods. There is also mention of the need for Lorentz invariance in any viable theory, which complicates the exploration of four-dimensional string theories.
mmzaj
a non-expert question !
hi
From what i understand , the number of spacetime dimensions needed by strings theory to be consistent arises due to the quantization of the classical action of the string , given that there shouldn't be tachyonic states in the mass spectrum of the theory . my question goes like this : why don't physicists look for a new quantization process that gives 4 dimensions , and looks like the known quantization when the string shrinks to a point particle , so that Q.M is modified for the sake of strings theory , but remains correct for our classical picture where particles are point like objects .
in other words : strings theory modifies G.R by adding some corrections to einstein-hilbert action - right ??- that leave the action intact for large scales , but it doesn't seem to do the same when it comes to quantum mechanics ! it certainly says a lot about QFT , but QM is a given in the formulation of strings theory !
excuse my technical terms , I'm not an expert , i just have an interest in the subject .
is it that my question isn't worthy of response or what :rolleyes:
I am an amature and my opinion is of little consequence here, but I would suggest that your question is probably too broad to answer without writing a textbook. Try narrowing it down and be more specific.
Also, this forum is jealously gaurded by persons who believe it should only be for discussion of papers published in peer-reviewed jounals. Your quesion sounds like you may be developing your own ideas...a dangerous practice when all you are expected to do is to climb up on the shoulders of giants.
Good luck.
I demand an answer! In under 10 hours! In the middle of the night!
mmzaj said:
hi
That's certainly a very interesting idea. The problem is that it's just words (for now). There is clear way to generalize the quantization process. But I think it's an interesting idea...But without any specific idea about how to go about it, it's just speculation.
I don't know whether anybody has ever made any attempt in that direction. And I don't know if anyone has ever spent some time thinking about it. It's the first time I hear the idea and it's interesting.
You are right that string theory has the standard quantization approach as a starting point. It does not at all propose any modification of quantum mechanics. If you were to quantize classical strings in different way then the theory would no longer be called string theory but something else. Again, it' san interesting proposal but from the idea to an actual implementation involves a huge step and it's not clear at all how one would get started.
starkind said:
... by persons who believe it should only be for discussion of papers published in peer-reviewed jounals. Your quesion sounds like you may be developing your own ideas...
Don't worry starkind, mmzaj is on very safe ground. And it is a good thing that the mentors keep the bar raised because it encourages people to look in the literature for their ideas. It can be educational to do a search and find out where what you have thought up overlaps with some peer-review journal research---as often happens.
In this case mmzaj have you looked here?
http://en.wikipedia.org/wiki/Non-critical_string_theory:_Lorentz_invariance
This several times makes special mention of the D = 4 case.
Like here: "Since any value of dimension can be used, and especially d=4, the applications could be more realistic..."
I am not saying that Wikipedia is entirely reliable, or that the idea here is the same as yours. But there may be some overlap.
Also you might look here:
this article has further references to books and other source material
It begins: "The non-critical string theory describes the relativistic string without enforcing the critical dimension. Although this allows the construction of a string theory in 4 spacetime dimensions, such a theory usually does not describe a Lorentz invariant background. Thus it is not a suitable theory of everything. However, there are recent developments which make possible Lorentz invariant quantization of string theory in 4-dimensional Minkowski space-time.
There are several applications of the non-critical string..."
I'm not well-informed about this but perhaps tossing out these links can be a little help to you.
Several years ago, some of the LQG theorists used their bizarro quantization process (nonseperable/huge hilbert space, Polymeyer states, etc) on the bosonic string.
AFAIK that's the only case of using nonstandard quantization procedures w.r.t string theory perse.
Suffice it to say, it wasn't well recieved, pretty much b/c it missed all the quantum anomalies of the system, which is bad.
Additional dimension in string theory are actually a GOOD thing, because otherwise string theory in 4 dimensions would be too simple, i.e., it could NOT accommodate specific interactions of the Standard Model of elementary particles. Perhaps it could be done with less than 10 dimensions, but certainly not with only 4 dimensions.
  • · Replies 26 ·
  • · Replies 47 ·
10K
  • · Replies 21 ·
  • · Replies 24 ·
