Degrees of Freedom of an electron
The discussion centers around the concept of degrees of freedom for an electron, particularly in relation to its wave function and spin. Participants explore the implications of representing the electron as a spin-1/2 particle and the mathematical formulation of its wave function.
  • One participant notes that the electron, being a spin-1/2 particle, requires a two-component wave function and discusses the transition to a four-component spinor representation.
  • There is confusion expressed about the relationship between the degrees of freedom of the electron (2 for spin up/down) and the eight independent components of the wave function, which includes complex elements.
  • Another participant mentions the positron, suggesting that it also has two degrees of freedom, leading to a total of four degrees of freedom when considering both particles.
  • A recommendation is made to avoid referring to the Dirac field as a "wave function" and to consider the Dirac equation in the context of classical wave equations analogous to Maxwell's equations for spin-1 particles.
Participants express confusion and seek clarification on the relationship between degrees of freedom and the wave function's complexity. There is no consensus on how these concepts interrelate, indicating ongoing debate.
Participants highlight the complexity of the wave function and its components, but the discussion does not resolve the assumptions or definitions that underlie these concepts.
Neitrino
Dear PF,
I have a question about degrees of fridom.
Electron is 1/2 spin particle so it needs 2 component wave function. But instead haveing 1 equation of second order we linearize and have two equations of order 1 for two spinors and these two equations can be re-written in one equation for 4 component spinor.
But this four component wave function has complex components ...and so there are eight independent elements in wave function.
What I am confused is that electron has degrees of freedom 2 (spin up/down) and wave function 8 ? correcct or what I don't understand? or complexity of wave function does not account in degrees of freedom?
Thanks
Nick
Stupid question ? :(
There is also the positron, with its two degrees of freedom. Thus, we have four of them.
And for a single "degree of freedom" of a wave we need one second order or two first order equations.
I also recommend you not to name the Dirac field psi "wave function", and to ignore all texts which use such a naming convention. Think of the Dirac equation as a classical wave equation, as the analogon of the Maxwell equation for particles with spin 1/2.
  • · Replies 39 ·
