Simplifying a trigonometric expression
The discussion revolves around simplifying a trigonometric expression involving multiple cosine terms set to zero. Participants explore various methods to manipulate the equation, including the use of double angle identities and sum and difference formulas.
  • One participant attempts to break down the expression using double angle identities, while another explores the sum and difference formula for cosines. There are questions regarding the correctness of simplifications made in the process.
Participants are actively engaging with different approaches to the problem, with some offering guidance on methods while others question the accuracy of specific steps taken. There is a mix of attempts to clarify and verify reasoning without reaching a consensus.
Some participants express uncertainty about the simplifications and substitutions made, indicating potential misunderstandings or assumptions that may need to be addressed further.
Petkovsky
cos(4x) + [tex]\sqrt{2}[/tex]cos(3x) + cos(2x) = 0
Ok, so break down everything to a double angle and i get:
2cos^2(2x) - 1 + sqrt(2)*(sqrt((cos(2x) + cos^2(2x))/2) - sqrt((1-cos^(2x)*(1-cos(2x))/2) + cos(2x) = 0
...which is quite complicated to solve even if i substitute cos(2x) with 't'.
I also tried another aproach:
2cos^2(2x) - 1 + sqrt(2)*(cos(2x)cos(x) - sin(2x)(sin(x)) + 2cos(2x) - 1 = 0
here i aimed to complete a square but i can't see how.
Can you please give me some advice on how to continue or use another method
Hello.
I used the Sum and Difference Formula for cosines.
Def: cos(a)+cos(b) = 2*cos((a+b)/2)*cos((a-b)/2)
Then, I let a=4x and b=2x
The original equation's LHS becomes
= 2cos((4x+2x)/2)*cos(4x-2x/2)) + [tex]\sqrt{2}[/tex]cos(3x)
= 2cos(3x)cos(2x) + [tex]\sqrt{2}[/tex]cos(3x) by simplifying
= cos(3x)[2cos(2x) + [tex]\sqrt{2}[/tex]] by distributive property
Thus, cos(3x) = 0 or 2cos(2x) + [tex]\sqrt{2}[/tex] = 0
Hope this helped.
Thank you
konthelion said:
Hello.
= 2cos(3x)cos(2x) + [tex]\sqrt{2}[/tex]cos(3x) << -- didnt you make a mistake here?
Didnt you make a mistake?
Shouldn't it be = 2cos(3x)cos(x) + [tex]\sqrt{2}[/tex]cos(3x)?
Anyway thanks for the help.
Yes, sorry.
sin(3x) = cos(x-30)
How about this one?
Where should I start from?
Ok i got it :)
