Finding a Vertical Force given friction and a horizontal force
The problem involves determining the smallest vertical force required to move a box resting on a horizontal surface, given a horizontal pulling force and the coefficient of static friction. The box has a weight of 50 N and is subjected to a horizontal force of 10 N.
  • Participants discuss the relationship between the forces acting on the box, including friction and normal force. There is an exploration of how to calculate the force of friction and its relation to the vertical force needed to initiate movement.
The discussion is active, with participants questioning the assumptions about the forces involved and exploring different interpretations of the problem. Some guidance has been offered regarding the equations of motion and the forces in play, but no consensus has been reached on the final approach.
Participants are working within the constraints of static friction and the conditions of the problem, including the weight of the box and the horizontal force applied. There is an ongoing discussion about the role of the normal force and how it relates to the vertical force needed to overcome friction.
crazyog
[SOLVED] Finding a Vertical Force given friction and a horizontal force
Problem:
A box with a weight of 50 N rests on a horizontal surface. A person pulls horizontally on it with a force of 10 N and it does not move. To start it moving, a second person pulls vertically upward on the box. If mu(s) =0.4 (coefficient of static friction) what is the smallest vertical force for which the box moves?
(answer: 25 N)
I think I might use F(s)= mu(s)*normal force
because if (mu*n) > F(s) then the object will move (?)
but then I am not really sure what to do with the 10N
My original thoughts would be =0.4*50N will give you 20N for the force of friction but that does not give me a vertical force
If I were to just think of the vertical force as the normal force then it would just be 50N..?
I'm confused, any help is greatly appreciated, thanks!
Maybe write it out clealry for yourself. What are the forces in each direction? What are the equations of constraint?
So for the horizontal force is it: 10- fk = ma where fk is equal to mu*n
10-(.4*50) = ma
-10 = ma
and for the vertical mg= n
mg = mg
Why mg = n for the vertical? What about the new vertical force for which you are trying to solve?
Oh I see,I think I understand, if the normal force is 25 then it will be
10 -(.4*25)=0
so a force of 25 is able to overcome the force of friction.
thanks!
  • · Replies 41 ·
  • · Replies 42 ·
