Quick question. Latent heat problem.
  • Thread starter Thread starter new324
    Heat Latent heat
The discussion focuses on calculating the total heat (Q) required to convert 456 grams of ice at -25°C into water at 25°C. The specific heat of ice is 2090 J/kg·K, the specific heat of water is 4186 J/kg·K, and the latent heat of fusion of water is 33.5 x 10^4 J/kg. The correct formula to use is Q = Qwater + Qice + Qlatent, where Qlatent is calculated as m * L and Qice is determined using Q = cmΔT.
  • Understanding of specific heat capacity
  • Knowledge of latent heat of fusion
  • Familiarity with the formula Q = mcΔT
  • Basic principles of thermodynamics
  • Calculate heat transfer using Q = mcΔT for different substances
  • Explore the concept of phase changes and their energy requirements
  • Learn about the implications of specific heat in climate science
  • Investigate real-world applications of latent heat in engineering
Students studying thermodynamics, educators teaching heat transfer concepts, and professionals in fields requiring thermal energy calculations.
new324
Allright, I may sound stupid on this one.
How much heat (Q) is required to change 456 g of ice at -25(degrees celsius) into water at 25(degrees C). The Specific heat of ice is 2090 J/kg K, the specific heat of water is 4186 J/kg K. The latent heat of fusion of water is 33.5*10^4 J/kg.
Is this just going to be Qwater+Qice+Qlatent? Where Qlatent is m*L?
[tex]Q = cm\Delta T[/tex]
and
[tex]Q = mH_f[/tex]
I think you have the right idea, but your notation is a little awkward.
cookiemonster
Thanks cookiemonster. I appreciate the help.
10K
