Math Struggles: Geometric Series & Paying Off a $200 Balance
The discussion revolves around a problem involving the payment structure of a credit card balance of $200, specifically focusing on the application of geometric series to determine the time required to pay off the balance when making minimum monthly payments.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore the conditions under which the minimum payment changes and how to express the remaining balance as a geometric sequence. Questions arise about the calculations needed to determine the number of payments required to reduce the balance to a specific threshold.
Some participants have offered insights into the mathematical relationships involved, such as defining the remaining balance after each payment and the implications of the geometric series. There is an ongoing exploration of how to systematically approach the problem and connect the concepts involved.
Participants note the importance of understanding the minimum payment structure and the transition points in the payment schedule, as well as the need for clarity in defining variables related to the balance and payments.
Calixto
What the heck?
The minimum monthly payment for a credit card is the larger of $5 or 1/25 of the outstanding balance. If the balance is less than $5, then the entire balance is due. If you make only the minimum payment each month, how long will it take to pay off a balance of $200?
Clearly, this has to do with geometric series. I can conceptually understand this problem, but I'm having trouble putting it into mathematical terms while relating to geometric series. If you have any advice, I would greatly appreciate it. Thanks.
First, when do you start making a minimum payment of $5? x/25= 5 when x= 125 so how many payments will be required to bring the balance down to $125? If your initial balance is S and you pay a fraction r of that each month, you first payment will be rS and the remaining balance S- rS= S(1-r). Your second payment will be r(1-r)S and the remaining balance then will be S(1-r)- r(1-r)S= (1-r)(S- rS)= (1-r)2S.
The remaining balance, after n payments, is the geometric sequence (1-r)nS. For what n is (1- 1/25)n(200)< 125? At that point the balance will be between 120 and 125 and will require 120/5= 22 payments of $5 each and a final payment of less than $5.
Calixto said:
What the heck?
oh … I have never seen such language!
Tush! And pish!
Hi Calixto! :smile:
Geometric sequence, actually.
General advice:
Be systematic.
Choose a name, like Pn, for the amount of money remaining after n months, and then find the formula connecting Pn and Pn-1. :smile:
Ok thanks HallsOfIvy, that helps a lot. And sorry tiny-tim for using such offensive language.
  • · Replies 16 ·
  • · Replies 32 ·
13K
