Does plywood follow hooke's law
  • Thread starter Thread starter Amy54
    Hooke's law Law
The discussion revolves around whether plywood adheres to Hooke's Law, particularly in the context of Young's modulus and beam deflection. Participants are exploring the material properties of plywood and its behavior under stress.
  • Participants question the applicability of Hooke's Law to plywood, considering its layered structure and whether Young's modulus is consistent across the material. There are discussions about the conditions under which materials follow Hooke's Law and the implications of material characteristics on this behavior.
The conversation is ongoing, with various interpretations of how plywood behaves under stress being explored. Some participants have provided insights into the general applicability of Hooke's Law, while others have raised specific considerations regarding the material's properties.
There is an indication that the discussion is constrained by assumptions about material behavior and the specific conditions under which Hooke's Law is applied. Participants are also considering practical scenarios, such as the bending of plywood sheets under weight.
Amy54
does plywood follow hooke's law? is the young's modulus for plywood constant across the beam? :) and if u have any other hints with deam deflection I am willing to have them :P
thanks!
Most things follow Hooke's law for small enough deflections - it depends how far you need to push it!
I would have thought that if there were enough layers of lamination then the longtitudanal/transverse ones would cancel out to give a uniform sort of behaviour.
As a caveat to what MGB wrote: Most materials will follow Hooke's Law. However, the form of the law that it follows may not be what you are thinking of. The most generally quoted form of Hooke's is for 1-D, linear, isotropic, homogeneous materials, i.e. [tex]\sigma =\epsilon E[/tex].
Hooke's law in its most general form contains 81 variables that can accommodate pretty much any material characteristic in all three dimensions. So to answer your question, does plywood follow Hooke's Law...yes it does. Does it follow the 1-D description that everyone knows? No. It does not.
But if you just want to know if an 8x4 sheet of ply will bend if you stand in the middle it should be enough.
  • · Replies 35 ·
