Proving Similarity of Matrices: A & B
  • Thread starter Thread starter ehrenfest
    Matrices
The discussion revolves around proving the similarity of two pairs of matrices. The first pair consists of matrices with varying off-diagonal elements, while the second pair features matrices with different structures but the same eigenvalue. Participants are exploring the algebraic conditions under which these matrices can be shown to be similar or not.
  • Participants discuss the need to express the similarity condition B=P^{-1}AP for some invertible matrix P. There are attempts to derive equations from this condition, with some questioning the effectiveness of their approaches. Others suggest examining eigenvectors and eigenvalues as a potential avenue for understanding similarity.
The conversation is ongoing, with participants sharing their algebraic manipulations and questioning the assumptions made about the matrices. Some have provided specific conditions under which the matrices are not similar, while others are still exploring the implications of their findings without reaching a consensus.
There is a mention of the original poster's prior attempts to solve the problem using elementary methods, and some participants express concern that not all may be familiar with eigenvalues, which could affect the discussion's direction.
ehrenfest
1) Show that for any real numbers a and b, the matrices
[tex]\left( \begin{array}{cc}<br /> 1 & a \\<br /> 0 & 2 \\<br /> \end{array}\right)[/tex]
and
[tex]\left(\begin{array}{cc}<br /> 1 & b \\<br /> 0 & 2 \\<br /> \end{array}\right)[/tex]
are similar.
2) Show that
[tex]\left( \begin{array}{cc}<br /> 2 & 1 \\<br /> 0 & 2 \\<br /> \end{array}\right)[/tex]
and
[tex]\left(\begin{array}{cc}<br /> 2 & 0 \\<br /> 0 & 2 \\<br /> \end{array}\right)[/tex]
are not similar.
We want to show that B=P^{-1} A P holds for some P in the first case and holds for no P in the second case. So I let P be an arbitrary 2 by 2 matrix and just wrote out the four equations that you get using the explicit formula for the inverse but that failed . So what is the trick...
anyone?
There is no "trick", there is only algebra! You say you wrote out the four equations, using an arbitrary (invertible?) 2 by 2 matrix. That should work. Exactly what did you get?
By the way, if B= P^{-1}AP, then, multiplying both sides, on the left, by P gives PB= AP. That might be simpler to use for an "arbitrary 2 by 2 matrix".
Might be a good idea to look at the eigenvectors of each matrix.
True, but:
1. Since Ehrenfest said he had already tried an elementary way that should work, I thought it best to encourage him in that. He may not know about eigenvalues yet.
2. While two matrices having different eigenvalues cannot be similar, having the same eigenvalues does not necessarily mean they are similar.
OK. Here is the solution to part 2: Let
P = [tex] \left( \begin{array}{cc}<br /> w & x \\<br /> y & z \\<br /> \end{array}\right)[/tex]
Then, if we write equations for each element of AP=PB, where A is the first matrix and B is the second matrix, we see that w=y=0 and a matrix with a column of zeros is clearly not invertible.
We can do the same thing for part 1) and obtain PA=BP (where A is the first matrix and B is the second one) if x=y=0 and w=b and z=a. Then P is invertible whenever a or b are not zero. If they are both zero, this is trivial. If a is zero and b is nonzero we let x=b,z=1, and w= anything nonzero, y = 0. And then when a is nonzero and b is zero do the "same" thing.
10K
  • · Replies 46 ·
9K
