Electric field as a function - potential
The discussion revolves around calculating the electric potential from a given electric field function, specifically E = E_o*e^(-r/R), where E points away from the origin. The problem involves understanding the implications of the electric field's direction and integrating the function to find the potential at a point r, with zero potential defined at infinity.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the meaning of the electric field pointing away from the origin and its implications for the integral. Questions arise about the integration of the exponential function and the setup of the integral for calculating potential. There is also inquiry into whether a point charge is implied at the origin.
The discussion is ongoing, with participants providing insights into the integral's structure and the relationship between the electric field and the radial distance. Some guidance on substitution for integration has been suggested, but there is no consensus on the interpretation of the charge situation or the integration process itself.
Participants note the absence of explicit information regarding a charge at the origin, focusing instead on the electric field's characteristics and the mathematical approach to finding potential.
scholio
electric field as a function -- potential
assume that the electric field in space is given by E = E_o*e^(-r/R) where r is the radial distance away from the origin and E_o and R are constants. E points away fro the origin. Calculate the electric potential at any point r if zero potential is taken at r = +infinity.
i should get electric potential V(r) = E_o*R*e^(-r/R)
point charge electric potential V = V(r) = kq/r where k is constant = 9*10^9, q is charge, r is distance
electric potential difference deltaV_AB = V_B =V_A = - [<integral>E*dr] from r_A to r_B
what does it mean that E points away from the origin, how does knowing that affect the problem?
what is the integral of the E function, how integrate the e^(-r/R) portion specifically?
if i let r = infinity, then in the E function then e^(-infinity) = 0, so the function goes to zero
any tips on how to get started appreciated...
scholio,
The integral is:
[tex] \Delta V_{ab} = -\int\limits_{a}^{b} \vec E\cdot d\vec r[/tex]
and so since there is a dot product inside the integral, you need to know the (relative) directions of [itex]d\vec r[/itex] and [itex]\vec E[/itex] in order to write down the integral for this particular problem.
the problem states that E points away from the origin. and r is the radial distance away from the origin. so does that make E negative and dr positive?
so now do i sub in the function in for E in the integral, how do i integrate e^(-r/R)?
since i want to calculate for electric potential V, is the charge at the origin, thus a point charge?
No, it means that r and E both point in the same direction- so their dot product is just the product of their lengths.
Use the substitution u= r/R.
??There is no mention of a "charge at the origin", just an electric force field- no mention of what causes the force field.
  • · Replies 22 ·
  • · Replies 16 ·
