Find Equation of Plane: 4x-3y-z-1+K(2x+4y+z-5)=0
  • Thread starter Thread starter mikee
    Plane
The discussion focuses on finding the equation of a plane defined by the intersection of the planes 4x - 3y - z - 1 = 0 and 2x + 4y + z - 5 = 0, which is parallel to the x-axis. The method involves determining the line of intersection of the two planes and using a direction vector <1, 0, 0> to establish the normal vector of the desired plane. The normal vector can be derived from the equation format Ax + By + Cz = D, where A must equal 0 due to the plane's parallelism to the x-axis. The solution requires solving for the parameters B and C by substituting points from the line of intersection into the plane equation.
  • Understanding of plane equations in 3D space
  • Knowledge of vector representation of lines and planes
  • Familiarity with the concept of normal vectors
  • Ability to solve systems of equations
  • Learn how to find the line of intersection of two planes
  • Study the method of using direction vectors and normal vectors in plane equations
  • Explore the concept of parametric equations in 3D geometry
  • Practice solving for parameters in equations involving multiple variables
Students studying geometry, particularly those focusing on 3D space and plane equations, as well as educators teaching these concepts in mathematics or physics courses.
mikee
Hello i just had a quick question, I am asked to Find the equation of the plane that passes through the line of intersection of the planes 4x - 3y - z - 1 = 0 and 2x + 4y + z - 5 = 0 and parallel to the x - axis.
Now i no if it gave you a point say A(3,4,5) i would use those as my x y and z values to solve for K in the equation 4x-3y-z-1+K(2x+4y+z-5)=0 and therefore finding the equation of the plane, but since it doenst give me a point and just a bit of information saying that it is parralel to the x axis, would i just use the elimation method to find the parametric equations for x y and z and then with that equation solve for the parameter let's say (t) and then therefore find points x,y,z and use those to solve for K?
It is giving you one direction vector <1,0,0>
and you need second direction vector which you can find by finding the line equation at which two planes intersect.
(I am not sure how to find line equation of the intersection -
but I think converting both planes to vector form and making r1 = r2 would solve the problem.
There might be easier way)
A plane does not HAVE a "direction vector", it is determined by a normal vector. I think what rootX meant was that you can use <1, 0, 0> as one of two vectors parallel to the plane whose cross product gives the normal vector. I think a simpler way is this: you know that any plane can be written in the form Ax+ By+ Cz= 1 where <A, B, C> is a normal vector to the plane. Saying that the plane is perpendicular to the x-axis tells you that the vector rootX mentioned, <1,0,0>, in the direction of the x-axis, is perpendicular to that: <A, B, C>. <1, 0, 0,>= A= 0.
The line of intersection of two planes can be determined by solving the the equations of the planes for two of the coordinates in terms of the third. You can then use that third coordinate as the parameter. Knowing that the entire line is in the plane, you can choose any two points on the line, put their coordinates into the equation of the plane and solve for B and C.
  • · Replies 16 ·
