Stern Gerlach Gradient Field Strength
The discussion centers on calculating the gradient magnetic field for the Stern-Gerlach experiment using two magnets, one with a sharp edge and the other flat. Robert seeks to determine the gradient based on the dimensions of the magnets, while Hans emphasizes the importance of using the gradient of the inproduct of the magnetic moment and the magnetic field. The formula provided for the magnetic field involves the magnetic moment and distance, indicating a need for integration to derive the total magnetic field accurately.
  • Understanding of magnetic fields and forces
  • Familiarity with the Stern-Gerlach experiment
  • Knowledge of magnetic dipole moments
  • Basic calculus for integration techniques
  • Research the mathematical derivation of the gradient of the magnetic moment and magnetic field
  • Explore numerical integration techniques for magnetic field calculations
  • Study the principles of magnetic dipole fields and their applications
  • Examine experimental setups for the Stern-Gerlach experiment
Physicists, experimental researchers, and students interested in quantum mechanics and magnetic field applications in particle physics.
rwhitman
I am trying to recreate the Stern-Gerlach experiment and am having trouble trying to calculate the gradient magnetic field. I am using two magnets with one having a sharp edge and the other flat. I have calculated what the deflection will be of the electron will be in terms of the gradient field, but I do not know how to calculate what the gradient is knowing the dimensions of the magnets.
~Robert
Make sure you use the gradient of the inproduct of the magnetic moment and the
magnetic field rather than the gradient of the magnetic field itself.
[tex]\vec{F}_{magn}\ =\ \textsf{grad}\left( \vec{\mu}_e\cdot<br /> \textsf{B} \right)[/tex]
What you could do is assuming that every little volume of magnetic material is a
point dipole field like this:
[tex]\textsf{B}~ = ~ \ \frac{\mu_o\mu_e}{4\pi r^3}\ \ \left(\ 3\ \frac{xz}{r^2}, \quad 3\ \frac{yz}{r^2}, \quad 3\ \frac{zz}{r^2}-1\ \right)[/tex]
Assuming that they all point in the same direction you can derive the total
magnetic field by integration (analytic or numerical)Regards, Hans.
  • · Replies 24 ·
  • · Replies 32 ·
  • · Replies 17 ·
