What are the fundamental principles of matter and its properties?
  • Thread starter Thread starter SigInt
    Time
The discussion centers on fundamental principles of matter and its properties, addressing misconceptions about area, mass conservation, volume conservation, atomic theory, and density. The conservation of mass principle is affirmed as true, stating that mass is neither created nor destroyed. The participants clarify that mixing substances can lead to volume changes, disproving the conservation of volume principle. Additionally, the atomic theory is validated, emphasizing that all matter consists of particles in constant motion, with density being one of several properties affected by physical changes.
  • Understanding of basic physics concepts, including mass and volume
  • Familiarity with the conservation laws in physics
  • Knowledge of atomic theory and particle behavior
  • Basic principles of physical changes in matter
  • Study the principles of conservation of mass and energy in physical processes
  • Explore the implications of atomic theory in modern chemistry
  • Investigate experiments demonstrating volume changes during mixing
  • Learn about the relationship between density, mass, and volume in physical changes
Students in physics and chemistry, educators teaching fundamental concepts of matter, and anyone interested in the principles governing physical properties and changes in substances.
SigInt
Hey all, I need a lot of help in very little time, as the project is due tomorrow before 3pm. (I know, I should have started it sooner, but I got extremely busy over the week-end and didn't have time)
anyways, I have 25 questions that need to be answered, and I'll give an answer, and I need to know if its right or wrong and if its wrong, how to correct it.
first 5 questions,
1. Area is the number of square units (1 unit)(1 unit) that are contained in the boundaries of a two dimensional figure.
False. (can't it also be in 3d as well?) Area is whatever is inside of the boundaries of any 2d or 3d object.(?)
2. The conservation of Mass principle says the mass cannot change in any physical process.
True. The principle states that mass is neither created nor destroyed, just moved from one form to another. It also states that the mass is constant, but its the amount of energy in anyone form may change.
3. However, if I mix one quart of ice tea wtih one cup sugar, I can observe that I will not end up with one quart + one cup of mixture. I cannot simply sum the two volumes before they were mixed and arrive at the same total volume after they are mixed. This proves that there is not a conservation of volume principle.
True. (? need help with why its true)
4. All matter is made up of very tiny peices. These very tiny pieces are particles. These particles are constantly in motion; between the particles there is nothing but empty space. All of the particles, in any particular substance, share exactly the same basic structure that is unique to the particles of that particular substance.
5. The density is the main change that affects a substance in a physical process.
False. Mass is also affected by a physical change and so is volume.
"1. Area is the number of square units (1 unit)(1 unit) that are contained in the boundaries of a two dimensional figure.
False. (can't it also be in 3d as well?) Area is whatever is inside of the boundaries of any 2d or 3d object.(?)"
No, that's completely wrong. In 3d "whatever is inside" is volume, not area. The statement is true.
"2. The conservation of Mass principle says the mass cannot change in any physical process.
True. The principle states that mass is neither created nor destroyed, just moved from one form to another. It also states that the mass is constant, but its the amount of energy in anyone form may change."
Assuming you are not talking relativity here, that's correct.
"3. However, if I mix one quart of ice tea wtih one cup sugar, I can observe that I will not end up with one quart + one cup of mixture. I cannot simply sum the two volumes before they were mixed and arrive at the same total volume after they are mixed. This proves that there is not a conservation of volume principle.
True. (? need help with why its true)"
Yes, it's true. As to why- Did you actually do the experiment? Assuming it comes out like this says, then there CAN'T be a "conservation of volume" principle. If an experiment violates some "principle", then that principle is not true!
"4. All matter is made up of very tiny peices. These very tiny pieces are particles. These particles are constantly in motion; between the particles there is nothing but empty space. All of the particles, in any particular substance, share exactly the same basic structure that is unique to the particles of that particular substance.
This is basically a statement of the "atomic theory". If you want more as to why it is true- well, same as for all physical theories: experimental evidence!
"5. The density is the main change that affects a substance in a physical process.
False. Mass is also affected by a physical change and so is volume."
Your answer doesn't even make sense. The statement says "that AFFECTS a substance". You are saying "is affected BY". You've reversed the meaning of the statement.
Thanks for the information. If I actually had the time to do 25 experiments, I would, except I don't. If that comes off as a bit harsh, I'm sorry, but its Finals week and I don't handle tests very well nor final projects like this.
  • · Replies 105 ·
  • · Replies 35 ·
  • · Replies 48 ·
  • · Replies 99 ·
