Thread Closed
Reaction mechanism
Share Thread Thread Tools
Jun10-08, 11:37 PM   #1
Reaction mechanism
Draw a step-by-step mechanism using curly arrows for the following transformation. You do not have to worry about stereochemistry of the final product.
2. Relevant equations
None
3. The attempt at a solution
So the reaction is shown in the diagram in the first line. Here's what I did:
1. Electrons in the O-H bond move toward the oxygen, and hydrogen gets detached, forming a negative charge on the oxygen
2. pi electrons from the double bond attack a H+ (from the acid) and forms a carbocation
3. The negative oxygen's electrons are attracted to the carbocation centre and draws the molecule into a ring formation
Does the mechanism make sense? Are there any other better ways of doing it? I know that there's another mechanism that involves the water molecule coming in, but I'm not sure about it.
Thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Jun11-08, 01:57 AM   #2
Admin
How likely is the presence of O- if it happens in the sulfuric acid?
Borek
http://www.chembuddy.com
http://www.ph-meter.info
Jun11-08, 11:09 AM   #3
Other Sciences 2012
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
When I examine reaction mechanisms and am given a catalyst (like H2SO4 in this case), I try to use it in the first step. In this case H+ is the catalyst.
Jun11-08, 02:01 PM   #4
Reaction mechanism
Hm... I attempted it again, using your suggestions, and here's my result.
Does that look better?
Jun11-08, 02:08 PM   #5
Other Sciences 2012
Recognitions:
That's close. I wouldn't have lost the primary alcohol. If the alcohol were labelled (as O-18), the label would probably be found in the product.
Also, the sulfuric acid probably adds across the double bond in Markovnikov fashion.
Thread Closed
Thread Tools
Similar Threads for: Reaction mechanism
Thread Forum Replies
[SOLVED] Reaction Mechanism (Shouldn't Be Too Difficult) Biology, Chemistry & Other Homework 0
Reaction mechanism Biology, Chemistry & Other Homework 0
Reaction mechanism Introductory Physics Homework 3
reaction mechanism Chemistry 2
Reaction Mechanism Chemistry 10
