Understanding Renormalization in Quantum Mechanics: Examples and Context
  • Context: Graduate
  • Thread starter Thread starter ObsessiveMathsFreak
    Example
The discussion revolves around the concept of renormalization in quantum mechanics, particularly its mathematical implications and examples. Participants explore its application in quantum field theory and condensed matter physics, addressing both theoretical and practical aspects of renormalization.
  • Some participants express confusion about the mathematical dubiousness of renormalization and seek concrete examples of quantities that require renormalization.
  • One participant describes the process of normalizing a wavefunction, noting that if the inner product does not equal one, a constant must be introduced to achieve normalization.
  • Another participant clarifies that the normalization of wavefunctions is distinct from the broader concept of renormalization, which occurs in the continuum limit of many degrees of freedom.
  • Examples are provided regarding scattering amplitudes and the behavior of theories at different energy scales, emphasizing that some theories are renormalizable while others are not.
  • Concerns are raised about the arbitrariness of renormalization prescriptions, with questions about how these affect physical predictions and the dependence of renormalized parameters on arbitrary mass scales.
  • One participant discusses the implications of choosing different renormalization prescriptions and how they can lead to different perturbation series behaviors.
  • Another participant mentions the Renormalization Group Equation (RGE) and its relationship to the scale dependence of renormalized parameters, questioning the behavior of parameters in the MS-scheme.
Participants generally agree that renormalization is a complex topic with various interpretations and applications. However, there is no consensus on the implications of different renormalization prescriptions or the nature of renormalized parameters in relation to physical measurements.
Participants highlight limitations in understanding the connection between renormalized parameters and measurable quantities, as well as the dependence on chosen renormalization schemes. The discussion reflects ongoing uncertainties and differing interpretations within the topic.
ObsessiveMathsFreak
I keep hearing about renormalization in quantum mechanics, frequently in the context of it's mathematical dubiousness. But no-one ever gives an example of this process. Could anyone give an example of a quantity that must be renormalised, along with some context? Even a very general one would do.
Lets say someone gives you a function which you can show to be an energy eigenstate because you act the hamiltonian on it to get the energy. If you take the inner product of the function/state/ket with itself it might come out to be one, it might not. If not its not normalised and you need to stick a constant out the front and inner product it again and set that inner product to one to compute the constant required.
FYI, renormalization ceased to be "mathematically dubious" a few decades ago. Unfortunately, the stigma remains.
Also, unfortunately, FunkyDwarf's reply doesn't seem to be the same renormalization that you are asking about, and is usually just called "normalizing the wavefunction".
A very good explanation of renormalization is given in Zee's quantum field theory book. Renormalization is something that happens when you take the "continuum limit", i.e., when you consider a system with many degrees of freedom and you take the limit where many becomes infinite. This is usually the case in condensed matter physics and quantum field theory.
For instance, let's say you consider the scattering of two particles with nearly zero energy, and you call the amplitude of that process [tex]g[/tex]. When you calculate the scattering amplitude, you end up having to do integrals in momentum space that usually blow up (their integrands grow like some positive power of momentum, for instance). Naively you say that there is something wrong. However, taking a cue from condensed matter physics, you might reason that your theory only gives a good "long distance" or "low energy" description of nature, and that at "short distances" or "high energies" it should be replaced by something else. It turns out that some theories are insensitive to what happens at "high energies", and those theories are called renormalizable. In essence, instead of pretending that your theory is good up to arbitrary high momenta, you say that it is good up to some value [tex]\Lambda[/tex], where [tex]\Lambda[/tex] is large, and (importantly), unknown. The important feature of renormalizable theories is that you can experimentally measure [tex]g[/tex] at one energy scale, and the theory will tell you how it changes with energy. The actual value of [tex]\Lambda[/tex] doesn't enter your final calculation.
The problem people had with renormalization had to do with getting rid of these seemingly infinite functions of [tex]\Lambda[/tex] in a consistent way. If you believe that your theory is complete, then, yes, you are on shaky grounds. But if you think of it as a low energy effective theory (which was explained by Kenneth Wilson), then you're ok.
To see an application in quantum mechanics in the spirit of effective field theories,
let me suggest the simple introduction
http://aps.arxiv.org/abs/hep-ph/9209266
consult RG related concepts
I really appreciated your nice explanation.
However, I am also reading about the renormalisation part of QFT recently. There are some problems I can't figure out in renormalisation procedure. That is, the physical prediction and the arbitrariness of the renormalisation procedure. Here are my questions to consult,
(1) The finite parts of the counter terms are actually arbitrary, to fix these counter terms, we have to use some renormalisation prescription( or scheme). Once we chose one renormalisation prescription, we have definite renormalized parameters, however, these renormalized parameters are in general NOT the physical quantities we measured in laboratory, right? Only if we choose the "physical subtraction" prescription, we get the physical measurable quantities. And, those renormalized parameters in certain momentum-subtraction prescription are running with an arbitrary mass scale, \mu, right? Even the measurable physical quantities which we obtained from the physical-subtraction would run with the scale.
Is my concept correct?
(2) The reason why we need those many prescriptions is that, choosing different finite parts of counter terms is equivalent to rearrange the perturbation series. So, in some cases, if we chose the renormalisation prescription appropriately, we would get a perturbation theory which has large contributions from first few terms of the perturbation series, and higher order terms are just tiny correction. Is my concept correct?
(3) Even we fixed the renormalisation prescription, we would still have the renormalized parameters depend on the arbitrary mass scale, \mu, and the differential equation which the Green function satisfies with respect to the change in \mu is called the Renormalisation Group Equation (RGE), right?
But, in the case of MS-scheme, the finite parts of the counter terms are all zero, hence the renormalized parameters don't run with scale?
Thanks so much for everyone who discuss with me or correct my concept.
Regarding arbitrariness of the prescriptions, the idea is that you know what your calculation is doing at low energies, but you don't know what it is doing at high energies. Now, there could be many theories that look different at high energies but the same at low energies (it is said that they flow to the same theory in the IR), so you essentially deform your theory so that it goes to one of those theories in the UV. For instance, you could deform it by adding mass to some particles (Pauli-Villars) or by varying the number of dimensions. You pick whatever regularization procedure works for you.
In the Wilsonian sense of renormalization, when you do calculations at low energies, you "integrate out" the high energy modes, and how you do that doesn't matter. When you suppress high energy modes then the highest energy modes that are left become your new "UV". You continue this process until the UV starts looking the same (albeit with a different factor scale). In other words, the functions you calculate become self-similar over different scales. At this point you have a UV fixed point, and the stuff that you suppressed earlier becomes irrelevant (they are perfectly hidden).
The whole subtraction business is just a way of doing the calculation, when you do perturbation theory, but the physics itself is contained in the RG equations. As far as MS is concerned, the fact that the finite parts are zero doesn't matter, since you still have a momentum dependent remainder.
http://arxiv.org/abs/hep-th/0212049v3"
Abstract:
An elementary introduction to perturbative renormalization and renormalization group is presented. No prior knowledge of field theory is necessary because we do not refer to a particular physical theory. We are thus able to disentangle what is specific to field theory and what is intrinsic to renormalization. We link the general arguments and results to real phenomena encountered in particle physics and statistical mechanics.
  • · Replies 57 ·
