| Thread Closed |
Reconciling several views of the electron wavefunction |
Share Thread | Thread Tools |
| Jun11-08, 05:00 AM | #1 |
Dear Friends:
This is to follow up on several recent threads regarding the electron wavefunction and uncertainty related thereto. Let me lay out a few viewpoints, which I am seeking to reconcile, to see what your thoughts are. 1) Solutions to Dirac's equation are obtained using the plane wavefunction: psi = u(p) exp[ip^u x^u] (1) where u(p) is a four component spinor. I have heard suggestions that one a) should not or b) cannot or c) need not use wavefunctions of any order higher the above, which is linear in x^u. 2) It is often stated / noted that the uncertainty inequality: delta x^u delta p^v >= (1/2) hbar (2) is exactly equal to (1/2) hbar when the wavefunction is of the Gaussian form (or variants that can be arrived at by "completing the square"): psi = u(p) exp[-(1/2)A x^u x_u] (3) see, for example, the calculation at http://en.wikipedia.org/wiki/Uncerta...trix_mechanics, and is greater than (1/2)hbar for a wavefunction other than a Gaussian. 3) Although the uncertainty inequality (2) applies equally to the time (0) and space (k) components, that is: delta t delta E >= (1/2) hbar delta x,y,z delta p_x,p_y,p_z >= (1/2) hbar (4) I am told that the canonical commutation relationship: [x^u,p^v] = i g^uv u,v=0,1,2,3 (5) actually should only be applied for u,v=j,k=1,2,3. Now, some questions: Q1) What is the uncertainty of a real electron in the ground state? Is it equal to (1/2)hbar or is it greater than (1/2)hbar? If the wavefunction is of the form (1), this is not a Gaussian, so I suppose this would means that the inequality in (2) applies. But, why would http://en.wikipedia.org/wiki/Uncerta...trix_mechanics be exploring Gaussian wavefunctions to begin with, other than as a matter of mathematical but not physical interest, if the solutions to Dirac's equation are always taken to be plane waves? Put in different terms, is there any circumstance under which a real, physical electron could have a Gaussian or near-Gaussian wavefunction and therefore have an uncertainty equal to or nearly equal to (1/2)hbar? If so, how does one reconcile this with taking solutions to Dirac's equation using only plane waves (1), which are complex sinusoids cos(x)+i.sin(x) that are spread all over? Q2) Now let's turn to the Robertson-Schrödinger relation, e.g., at http://en.wikipedia.org/wiki/Uncerta...inger_relation. The uncertainty relationship (2), (4) appears to be a consequence of the canonical commutation relationship (5) via the Robertson portion of Robertson-Schrödinger. But the Heisenberg inequalities (2), (4) apply equally to time / energy as well as the space / momentum components, and (5) is said to apply only to space / momentum components. When this limiting statement is made about (5) not apply to time / energy, are there some other assumptions behind it? That is, are there situations in which (5) does apply, with full four dimensional covariance, and are the situations where (5) is restricted to space / momentum components a special case and / or a case that involves particular assumptions? If so, what are these? Thanks, Jay. ____________________________ Jay R. Yablon Email: jyablon@nycap.rr.com co-moderator: sci.physics.foundations Weblog: http://jayryablon.wordpress.com/ Web Site: http://home.nycap.rr.com/jry/FermionMass.htm |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Reconciling several views of the electron wavefunction
| Wavefunction of a 2s hydrogen electron. | Advanced Physics Homework | 4 | ||
| Limitations on radial wavefunction for electron in an atom | Quantum Physics | 1 | ||
| Re: Reconciling quantum theory & relativity | General Physics | 5 | ||
| reconciling van der waal's equation of state with experimental observations | Introductory Physics Homework | 0 | ||
| Reconciling quantum theory & relativity (was: QFT Questions) | General Physics | 4 | ||
