Accumulation of Mass in Stellar Formation?
  • Context: Graduate
  • Thread starter Thread starter maverick_starstrider
    Mass
The discussion revolves around the role of dipole-dipole forces, particularly van der Waals forces, in the context of stellar formation and the accumulation of mass in dust clouds. Participants explore the implications of these forces compared to gravitational attraction, especially at small scales relevant to the formation of solar systems.
  • Some participants propose that dipole-dipole forces could play a significant role in stellar formation, particularly as particles in a dust cloud come closer together.
  • Others argue that in a Newtonian framework, the center of mass spherical harmonics expansion has a zero dipole moment, suggesting that dipole forces may not be relevant for gravitational interactions in stellar formation.
  • A later reply questions the applicability of spherical harmonics models to dust clouds, noting that these models can be time-varying and complex.
  • Some participants highlight that individual atoms and molecules do experience van der Waals forces, which may be comparable to gravitational forces at small distances.
  • There is a distinction made between electronic dipole-dipole forces and gravitational dipole forces, with emphasis on the former being relevant at the molecular level.
  • Concerns are raised about the numerical modeling of intermolecular forces in astronomical simulations, suggesting that current models may overlook these forces due to scale differences.
  • One participant recalls being taught about accretion disks and the role of gravity in mass accumulation, questioning why electronic forces were not discussed in relation to stellar and solar system formation.
Participants express differing views on the significance of dipole-dipole forces in stellar formation, with no consensus reached on their importance compared to gravitational forces. The discussion remains unresolved regarding the relative contributions of these forces.
Limitations include the dependence on specific models of gravity and the challenges of accurately modeling forces at different scales, particularly the transition from molecular to astronomical distances.
The recent post by shamrock5585 got me thinking. Most models of stellar formation and stuff basically involve an accumulation of mass through gravity building larger and larger mass. However, even if we assume that all the particles are of neutral charge we can still expect a dipole-dipole force as the particles get closer (through taylor series expansion). However, (if we briefly consider gravity as a Newtonian force instead of in terms of general relativity) I would be inclined to think that, due to the very small size of the constant G, that the dipolar term (although it is of the order 1/r^3) would be dominant as the particles begin to closely pack and yet I don't think I've ever heard of dipolar attraction being an important factor of stellar formation (although I'm a computational quantum many-body guy not an astro guy).
I guess my question is, is dipolar attraction ever considered in these sorts of models?
Astronomy news on Phys.org
The Earth (and any real astronomical object) is not a perfect sphere. A precision gravity model requires a treatment of the non-spherical shape. Spherical harmonics are one obvious choice. The obvious origin for such a spherical harmonics expansion is the center of mass. The center of mass spherical harmonics expansion has a zero dipole moment because a non-zero value would require a negative mass. So, no dipole moment for Newtonian gravity.
Higher order terms can be quite important, at least at close range. For example, the Earth's zonal quadrupole moment, J2, is one of the major perturbing factors in satellite orbits and dominates all other perturbing factors at geosynchronous satellites. Quadrupole moments only go so far. People have developed 360x360 spherical harmonics models for the Earth's gravitational field (http://cddis.nasa.gov/926/egm96/egm96.html" . JPL has developed Lunar gravity models up to degree and order 160.
I'm not talking about the Earth though I'm talking about stellar formation where you have a dust cloud which accumulates atom by atom, dust speck by dust speck to make a solar system.
What difference does it make, conceptually? There is a zero dipole moment in the center of mass spherical harmonics expansion of the gravitational field for any collection of mass because there is no such thing as negative mass.
One problem with a dust cloud is that the spherical harmonics model will be time-varying, but if you want to get real picky, so is the Earth's. The Earth rotates once per day, but this problem can be addressed by developing the spherical harmonics in a rotating frame that rotates with the Earth. Even so, the Sun and Moon cause tides, which results in a daily variation in the rotating frame spherical harmonics coefficients. Mass migrates northward during winter (northern hemisphere) and southward during summer, causing an annual variation in the coefficients. Mountains rise up and erode and continents move around, causing longer term variations.
Bottom line: An extremely detailed Earth gravitational model will have time-varying spherical harmonics coefficients. The same is true for a dust cloud.
But individual atoms and molecules do experience a dipole-dipole force (the van der waals force). And I'd imagine that the magnitude of that force is either of the same order or larger then the gravitational attraction at the distances between particles of a dust cloud.
NOTE: I am talking about an ELECTRONIC dipole-dipole force (from electron orbitals) not a gravitational dipole force coming from expanding the graviational force.
Electric dipoles result because there is such a thing as negative charge. There is no such thing as negative mass. A similar situation occurs in magnetism, except in magnetism there is no monopole moment rather than no dipole moment.
Ah, I see. You *are* talking about electric dipoles. Van der Waal forces occur at the molecular level. Astronomers don't even come close to modeling such short distances. The particles are deemed to have collided when the distance approaches some non-zero limit that is much greater than intermolecular distances. They do their modeling using doubles or floats, not extended precision numbers. Intermolecular distances and interplanetary distances don't mix well in the numerical representations used in simulations.
I just remember in my undergrad astro courses iit being taught how accretion disks form and how mass accumulates and then when particles start being ejected from the accretion disk plane by random thermal fluctuations you start to see spherical masses and we calculated approximate thresholds for when this kind of activity would occur all assuming the primary force involved in holding these masses cohesive was gravity when really, it seems to me, the most important factor would be van der waals forces.
Especially since, I remember there being a problem explaining the angular momentum a solar system has and one of the possible explanations was solar winds but the solar winds would also excite the particles which would further increase the importance of electronic intermolecular forces by introducing coulombic forces as ions are formed. But never once do I remember us actually talking about the role that electronic forces play in solar system and stellar formation.
  • · Replies 21 ·
  • · Replies 30 ·
  • · Replies 134 ·
13K
