Why Is 1 Bar Important in Cv or Kv Calculations?
  • Thread starter Thread starter TSN79
    Cv Value
The discussion revolves around the significance of the 1 bar pressure drop in the context of Cv and Kv calculations, which are used to determine the flow factor of valves. Participants explore the implications of this standard pressure drop for measuring flow and the relationship between pressure drop and flow measurement devices.
  • One participant expresses confusion about the role of the 1 bar pressure drop in Cv and Kv calculations, questioning its relevance when measuring flow at different pressure drops.
  • Another participant explains that 1 bar serves as a standard for valve manufacturers to test and measure Kv, providing a basis for comparing different valves and their flow restrictions.
  • It is noted that specifying a pressure drop effectively sets a minimum flow requirement, which may be necessary for accurate flow measurement.
  • A participant clarifies that CBI refers to a computerized Balancing Instrument, which measures pressure differences and flow rates, indicating that it requires a minimum pressure drop for accurate readings.
Participants have not reached a consensus on the implications of the 1 bar pressure drop in Cv and Kv calculations, and there are differing views on its necessity and impact on flow measurement.
There may be limitations related to the definitions of Cv and Kv, the specific requirements of flow measurement devices, and the assumptions underlying the use of 1 bar as a standard pressure drop.
This discussion may be useful for engineers, technicians, and students involved in fluid dynamics, valve design, or flow measurement instrumentation.
TSN79
Two questions;
1)
I'm struggeling to understand the concept of the Cv or Kv value, also known as the flow factor. In SI units this is defined as the flow through a valve (m3/h) at a pressure drop of 1 bar, or 100 kPa. Fair, and the formula for calculating it is easy enough. I enter my flow and the desired pressure drop (in this case 5 kPa). So where does this "1 bar" enter the picture?
2)
To measure the flow through a valve one connects a meter to it (called a CBI, made by Tour & Andersson). I always hear people saying that the valve needs to have a certain pressure drop in order for the flow to be measurable. Why is that? I always considered pressure drop as something one wants to avoid...
1)The 1 bar is the standard that the valve manufacturer uses to test/measure for the Kv (or 1 psi per gpm to calculate Cv for us in the US). That acts like the equalizer between different sizes and types. That also gives you more information when designing to know what kind of valve has what kind of flow restriction based on type.
2) It does depend on the valve itself, but by stipulating a pressure drop, you are effectively stipulating a minimum flow. I am not familiar with the term you use (CBI), but if it measures flow and requires a minimum pressure drop across it, it means that the instrument is incapable of measuring any smaller delta P than the stated minimum which is needed to calculate the flow rate.
I believe that CBI stands for computerized Balancing instrument. it is a handheld devise used to measure the pressure difference across a valve and the flow rate and temperature of the working fluid.
Good to know. Thanks.
  • · Replies 45 ·
