QM calculation of vacuum energy
The discussion revolves around the quantum mechanical calculation of vacuum energy, particularly its significant discrepancy with experimental observations, such as the Casimir effect. Participants explore the implications of this discrepancy and the broader context of quantum mechanics in relation to gravity and cosmological observations.
  • Some participants argue that a theory with predictions vastly different from experimental results would typically be dismissed, questioning why quantum mechanics is not similarly criticized given the vacuum energy discrepancy.
  • Others contend that quantum mechanics is not labeled as rubbish because it successfully predicts a wide range of phenomena, despite the challenges in extrapolating its predictions regarding vacuum energy.
  • It is noted that there is agreement between theory and experiment for the Casimir effect, suggesting that the issue may lie more with the comparison between vacuum energy and observed cosmological dark energy, which shows a discrepancy of 120 orders of magnitude.
  • Some participants highlight that the construction of quantum field theories assumes a Minkowski space, which does not account for gravity, and thus may not be relevant to the observed discrepancies in a gravitational context.
  • A minority viewpoint suggests that a significant revision of quantum mechanics may be necessary to address these discrepancies.
Participants express differing views on the implications of the vacuum energy discrepancy, with some defending quantum mechanics and others questioning its validity in light of the observed differences. There is no consensus on whether the current framework of quantum mechanics is sufficient or if it requires fundamental changes.
The discussion highlights limitations in the assumptions underlying quantum field theories, particularly regarding their applicability in gravitational contexts and the challenges of extrapolating results from quantum mechanics to cosmological scales.
battery
If I came up with a theory that had predictions 100 times larger or smaller than experimental observation my theory would labelled rubbish by scientists.The quantum mechanical calcualtion of vacuum energy is 120 zeros at odds with experimental observation ( casimir effect).Why aren't people labelling quantum mechanics as rubbish?
If that's all your theory can predict, then yes, it is totally rubbish. But if your theory predicts other things that actually WORK, and you are using the very effect of that theory right this very second, then how can it be labelled as rubbish?
And it isn't widely accepted that such vacuum energy has THAT high of an energy density. There are fringe physics and crackpots that may think so, but we have seen from experiments on casimir effect that such an effect is extremely small and extremely difficult to detect, and that IS within what QM has predicted as well! I can show you MANY other nonsensical effects using many-body quantum mechanics. Does this make QM rubbish? No. You have to know that extrapolating QM in such a way requires significant assumptions and simplifications (example: mean field approximation). It is such simplification that can easily be at fault. Full, real phenomena are very seldom solved without making such assumptions.
Zz.
As ZapperZ has already said, there is agreement between theory and experiment for the Casimir effect.
Do you mean the difference between vacuum energy and observed cosmological dark energy? In this case, rough calculations, as given in, e.g., Carroll's general relativity book, lead to a discrepancy between "theory and experiment" of 120 orders of magnitude. Other calculations give different results, but usually there is a large discrepancy.
Many people think that an accepted quantum theory that can be used for calculations is needed to explain this.
A minority, e.g. Roger Penrose, think that a large change in quantum mechanics is needed.
I don't really think this discrepancy is so weird. Remember that the construction of quantum field theories starts with the assumption that space-time is Minkowski space. This means that we're describing a universe where there is no gravity. The theories we construct in this way are in excellent agreement with experiments about everything, except this one thing that has no relevance whatsoever in a world without gravity.
  • · Replies 33 ·
  • · Replies 115 ·
10K
