Solve the Tricky Probability Problem: Drawing Cards from a Standard Deck
  • Thread starter davedave
  • Tags
    Probability
In summary, the probability of drawing an ace from a standard deck of 52 cards, given that one card is a diamond, is 1/13. This can be found using the conditional probability formula P(A l B)=P(A and B)/P(B) where A represents the event of drawing an ace and B represents the event of drawing a diamond. The correct answer can also be obtained by considering two cases: one card is a diamond and the other is not (with a probability of 1/13 for the non-diamond card to be an ace) and both cards are diamonds (with a probability of 2/13 for one of them to be the ace of
davedave
50
Suppose that you draw two cards without replacement from a standard deck of 52 cards.
Given that one card is a diamond, what is the probability that the other card is an ace?
How do you use the conditional probability formula P(A l B)=P(A and B)/P(B) to find the answer?
Thanks.
How exactly are you having difficulty using conditional probabilities?
Also what do you think A and B are?
Thanks.
i am the one that posts this problem
this is how i do it using the formula
p(ace l diamond)=p(ace and diamond)/p(diamond)
"D" means diamond
p(ace and D)=p(D not ace and D ace)+p(D ace and D not ace)+p(D not ace and D not ace)
=12/52 * 1/51 + 1/52 * 12/51+12/52 * 11/51 = 1/17
p(D)=P(both D)+p(1st D and 2nd not D)+p(1st not D and 2nd D)=13/52 *12/51 +13/52 * 39/51 + 39/52 * 13/51 =15/34
so, p(ace l diamond)=2/15 This is wrong.
The CORRECT answer in the book is 7/51.
Does anyone know how to get the answer?
Since there are the same number of aces in each suit (1), knowing the suit of the first card does not give you any more information about the probability that the first card is the ace of diamonds or the number of aces left. The probability the second card drawn is an ace is just the same as if you did not know the suit of the first card (or if you had not drawn the first card), 4/52= 1/13.
If you want a more detailed calculation:
There are 13 diamonds in the deck so, given the the first card drawn is a diamond, the probability the first card drawn is the ace of diamonds is 1/13, the probability it is not the ace of diamonds is 12/13.
If the first card drawn is the ace of diamonds, then there are 3 more aces in the 51 remaining cards: the probability the second card drawn will be an ace is 3/51.
If the first card drawn is not the ace of diamonds, then there are still 4 aces in the 51 remaining cards: the probability the second card drawn will be and ace is 4/51.
Given that the first card drawn is a diamond, the probability that the second card drawn is an ace is (1/13)(3/51)+ (12/13)(4/51)= 51/(13)(51)= 1/13.
where P(B) is the prob. of getting a diamond... and A is that for ace.
so P (A|B) = [ (13/52)*(4/51) + (4/52)*(13/51) ] / (13/52)
= 2*(4/51)
= 8/51
The answer is 1/13.
Is is true that P(Ace | Diamond) = P(Ace and Diamond)/P(Diamond).
For the denominator: P(Diamond) = 13/52 (13 diamonds, 52 cards)
For the numerator: The ONLY way to get both an Ace and a Diamond is to draw the ace of diamonds, so the numerator is 1/52.
Answer = (1/52)/(13/52) = 1/13
Thanks.
Two cases:
Case 1. one card a diamond, one card not - probability that non-diamond is ace is 1/13.
Case 2. both cards diamonds - probability that one is the diamond ace is 2/13.
Frequency of case 1 is 2x13x39
Frequency of case 2 is 13x12
Overall probability= 17/195
1. What is a tricky probability problem?
A tricky probability problem is a type of mathematical puzzle that involves using probability theory to solve a challenging and often counterintuitive question or scenario. These problems typically require careful analysis and creative thinking to find the correct solution.
2. How do I approach a tricky probability problem?
The key to solving a tricky probability problem is to carefully read and understand the problem statement, and then to break it down into smaller, more manageable parts. It can also be helpful to draw diagrams or create visual representations of the problem to aid in understanding. Additionally, using fundamental probability principles and logical reasoning can help guide your approach.
3. What are some common techniques for solving tricky probability problems?
Some common techniques for solving tricky probability problems include using tree diagrams, creating sample spaces, and using combinatorics to count possible outcomes. It can also be helpful to reframe the problem or look at it from different perspectives to gain new insights.
4. What are some common mistakes to avoid when solving tricky probability problems?
One common mistake when solving tricky probability problems is assuming that the problem is simpler than it actually is. It is important to carefully consider all possible outcomes and not overlook any potential solutions. Another mistake is relying too heavily on intuition, as tricky probability problems often involve counterintuitive scenarios.
5. How can I use tricky probability problems to improve my problem-solving skills?
Solving tricky probability problems can help improve your problem-solving skills by challenging you to think critically and creatively. They also require a strong understanding of fundamental probability principles, which can strengthen your mathematical foundation. By practicing with different types of tricky probability problems, you can enhance your overall problem-solving abilities and become a better critical thinker.
