Lagrangian is defined as the difference between kinetic and potential
The discussion centers around the definition and implications of the Lagrangian in physics, particularly in the context of classical mechanics and its relation to quantum mechanics. Participants explore concepts such as conservation, symmetry, and the mathematical representation of derivatives in the context of the Lagrangian framework.
  • One participant states that the Lagrangian is defined as the difference between kinetic and potential energy, questioning its conservation in particle interactions.
  • Another participant clarifies that the Lagrangian is part of Lagrangian mechanics, which can also apply to quantum mechanics.
  • A participant references Noether's theorem, suggesting that symmetries in the equations of motion correspond to symmetries in the Lagrangian, but questions whether this is entirely accurate.
  • One participant argues that the Lagrangian itself is not conserved, asserting that energy is the conserved quantity, and explains the principle of least action.
  • Several participants discuss the meaning of the symbol \partial with a small \mu symbol, explaining its relation to partial derivatives in space-time coordinates.
  • There is a discussion about the distinction between covariant and contravariant indices in the context of derivatives, with differing opinions on their treatment in quantum field theory.
Participants express differing views on the conservation of the Lagrangian and its relationship to symmetries and conserved quantities. There is no consensus on the accuracy of certain statements regarding Noether's theorem and the treatment of indices in derivatives.
Participants mention various assumptions and interpretations regarding the Lagrangian, conservation laws, and mathematical notation, indicating the complexity and nuance of the topic. The discussion reflects a range of understandings and interpretations of advanced concepts in physics.
faen
So after reading a bit particle physics, the lagrangian is defined as the difference between kinetic and potential energy: L = EK-EP. It is supposed to be conserved in particle interactions. However i don't know why it is conserved, so can anyone please explain to me why?
Thanks a lot :)
The Lagrangian is a part of a technique used in advanced classical mechanics called, not surprisingly, Lagrangian mechanics. The same basic idea can be applied to quantum mechanics. It will be difficult to understand the QM version before understanding the classical version.
I just read noethers theorem, so this is what i learned: The lagrangian leads to the equations of motions. So any symmetry observation in the equations of motion means that the symmetry must exist in the lagrangian of a wavefunction also because it is related to the equations of motions. And visa versa.. Am i right or did i get it wrong? :p
Hold on here, the lagrangian is not conserved ! A conserved quantity would be the energy, I mean total E= Ek + Ep. If L and E were both conserved, then Ek and Ep would be both conserved as well. There would be nothing happening whatsoever, no motion, no force.
If you integrate L along a physical trajectory, you will obtain a number (the action) which is less than for any other possible (but unphysical) trajectory. So L is not conserved but is (in some sens) minimum. Technically, this is nothing more than the principle of least action.
The way it is formulated, the action is not necessarilly least, it could be most or it even could just be stationnary, that is a local inflection point in the space of all possible trajectories. I state that to try to make it clearer, not to claim that "least action" is a bad name.
Thanks, i understand a bit more now. But was what i said in my previous post right or wrong?
Also, what does this symbol mean; [tex]\partial[/tex] with a small [tex]\mu[/tex] symbol either at top or bottom next to it?
In your previous post, you said that any symmetry of the equation of motion is also a symmetry of the lagrangian. I have not put too much thought in this statement, and I do not want to confuse you, but I would say that apart from symetry breaking mechanisms (spontaneous, dynamical), your statement seems all right.
But it is not what Noether's theorem is about. Noether's theorem is about the fact that, to any symmetry is associated a conserved quantity.
Energy conservation <-> time translation invariance
Momentum conservation <-> space translation invariance
Angular momentum conservation <-> space rotation invariance
This refers to the partial derivative with respect to space-time coordinates. So [tex]\mu\in[x,y,z,t][/tex] for instance, and [tex]\partial_{\mu}S[/tex] would be a 4-vector containing the partial derivative of the scalar [tex]S[/tex].
You need to check you metric [tex]g_{\mu\nu}[/tex] which could be (+,-,-,-) or (-,+,+,+) to define [tex]\partial_{\mu}V^{\mu}=g_{\mu}^{\,\,\,\,\nu}\partial^{\nu}V^{\mu}[/tex] (well really it defines the inner product of 4-vectors...)
Thanks, your explanations help :). So just to be sure i understood partial derivative right; [tex]\partial_{\mu}S[/tex] means that i get a vector where the first component is the partial derivative of x, then the next vector component is the partial derivative of y, and so on?
"you said that any symmetry of the equation of motion is also a symmetry of the lagrangian"
Nitpick, is that true necessarily, I haven't thought about that for awhile either. You got to be a little careful here I think and distinguish between the action, lagrangian and lagrangian density.
first term is time, then the three spatial.
Anytime you see V^mu it's a 4-vector {t,x,y,z} or rather {x0,x1,x2,x3}.
so basically what you said but with the first term is derivative wrt time.
edit: actually I think when learning classical mechanics they did something like {x,y,z,t}, but reagardless, yes, its just the notation for a derivative vector.
[tex]\partial ^{\mu} = (\frac{\partial }{\partial x^0},-\frac{\partial }{\partial x^1},-\frac{\partial }{\partial x^2},-\frac{\partial }{\partial x^3}) = (\frac{\partial }{\partial x^0},-\vec{\nabla})[/tex]
lower that index!
not according to my lecture notes.
[tex]\partial _{\mu} = (\frac{\partial }{\partial x^0},\frac{\partial }{\partial x^1},\frac{\partial }{\partial x^2},\frac{\partial }{\partial x^3}) = (\frac{\partial }{\partial x^0},\vec{\nabla})[/tex]
In QFT in flat spacetime, many people simply ignore upper and lower indices. This is because covariant and contravariant indices transform identically (numerically) when the basis is (pseudo-)orthogonal. Actually, when I say pseudo, I mean when you have a lorentzian metric, and it is not quite true that the components are equal : the are actually opposite for those dimensions corresponding to the negative part of the signature. If say you take (+,-,-,-), the time component is really unchanged, but the space components flip signs. However, in the end we do not really care because any time we want to evaluate the inner product we already know we must take a minus sign for the space components, so we usually forget those technicalities all together :smile:
Remember how we can canonically identify a tangent vector to the dual form which gives the projection on this vector ? In principle a tangent vectors and its (dual) forms are just the contravariant and covariant representation of the same (1-)tensor. But in euclidean space, the coordinates are the same if you choose an orthogonal basis. This basically is just the fact that orthogonal projection on a basis vector will give the same result as the projection along (dim-1) hyperplane spanned by the other basis vectors if (and only if) the basis is orthogonal.
Covariance and contravariance of vectors on wiki.
But if you want to keep track of indices, you should have
[tex]\partial_{\mu}=\frac{\partial}{\partial x^{\mu}}[/tex] and [tex]\partial^{\mu}=\frac{\partial}{\partial x_{\mu}}[/tex]
In the end, this just stems for the fact that we are doing symbolic manipulations : if you put a contravariant in the denominator, then you will pick up the inverse of the jacobian instead of the jacobian as would have been if the contravariant were in the numerator. There is not much more to these notations.
What I wrote earlier was wrong BTW, it should not have been
but
[tex]\partial_{\mu}V^{\mu}=g_{\mu\nu}\partial^{\nu}V^{\mu}[/tex]
this is great, my professor will give me a golden star =D
  • · Replies 49 ·
  • · Replies 48 ·
