How to generate high freqnecy (electromagnetic)
  • Context: Undergrad
  • Thread starter Thread starter atom888
    Electromagnetic
This discussion focuses on generating high-frequency electromagnetic signals, specifically in the MHz range. Users highlight the use of magnetic fields to manipulate electric fields for electron oscillation, suggesting that a switch capable of operating at millions of cycles per second is essential. A participant clarifies that MHz frequencies are common, with quartz oscillators being a standard method for generating these frequencies, which are then amplified for use in applications like radio transmission.
  • Understanding of electromagnetic theory
  • Familiarity with oscillator circuits and their components
  • Knowledge of quartz oscillators and their applications
  • Basic electronics skills, particularly in circuit design
  • Research the design and functionality of quartz oscillators
  • Explore radio transmitter technology and its components
  • Learn about signal amplification techniques for high-frequency signals
  • Investigate advanced oscillator designs for generating GHz and THz frequencies
Electronics engineers, radio frequency (RF) engineers, and hobbyists interested in generating high-frequency electromagnetic signals will benefit from this discussion.
atom888
Hi all,
This is frustrating. I've searched all over the net for how one can generate high freqency, maybe a few Mhz. The most I could get is using the magnetic field which in turn manipulate the electric field to oscillate the electron. Well, that would result in million of cycle per second. How can we do that? I suppose through a device in a circuit (maybe a switch that could open/shut at millions of times per second). Please give me some insight information if you're a pro in this area. Thx
I believe you're talking about a radio transmitter. Look at what capacitors do in oscillator circuits.
atom888 said:
Hi all,
Well, first of all, "a few MHz" isn't that high. There are plenty of GHz sources already, and people are starting to also generate THz source.
Secondly, most MHz sources (such as radio stations) use quartz oscillators to generate such frequency range. It then gets amplified.
Zz.
