Rock Thrown Vertically: Maximum Height & Time to Hit Ground | 24m/s Velocity
  • Context: Undergrad
  • Thread starter Thread starter Buffalob07
A rock thrown vertically with an initial velocity of 24 meters per second reaches its maximum height at 2.45 seconds, achieving a height of 31.39 meters. The position function is defined as s(t) = 2 + 24t - 4.9t², while the velocity function is v(t) = 24 - 9.8t. The total time for the rock to hit the ground, after reaching its peak, is calculated to be 4.98 seconds.
  • Understanding of quadratic functions and their properties
  • Knowledge of calculus, specifically derivatives for velocity calculation
  • Familiarity with kinematic equations in physics
  • Basic algebra skills for solving equations
  • Study the derivation and application of kinematic equations in projectile motion
  • Learn about the concept of derivatives in calculus and their physical interpretations
  • Explore the use of quadratic equations in real-world scenarios
  • Investigate the effects of air resistance on projectile motion
This discussion is beneficial for physics students, educators, and anyone interested in understanding the principles of projectile motion and kinematics.
Buffalob07
A rock is thrown vertically with the celocity of 24 meters per second. It reaches a height of 2+24t-4.9t^2 after t seconds. How many seconds after the rock is thrown will it reach maximum height? What is the maximum height in meters? How many seconds after the rock is thrown will it hit the ground? Round answers to the nearest hundredth. Thanks.
position = s(t) = 2 + 24t - 4.9t^2
velocity = v(t) = s'(t) = 24 - 9.8t
The maximum height will be reached when velocity equals 0 (because once the rock's velocity reaches 0, it will be come negative and start falling downward.
24 - 9.8t = 0
9.8t = 24
t = 2.45
So, to answer the first question, maximum height is reached at t = 2.45 seconds.
Now, to find the height reached, take the original position function and subtitute in the time...
s(2.45) = 2 + 24(2.45) - 4.9(2.45)^2 = 31.39.
The maximum height reached is 31.39 meters.
Someone else's input with the last question should be used. I tried doing it and I got an undefined answer, so I'm guessing I'm doing it wrong.
Continuing where IG left off... t = 2.45 s for the climb, and another 2.45s to come back down to the original position, at a height of 2 m. That's 4.9s so far. Now there's an additional 2m to go, and the velocity is now 24 m/s downwards.
from s = ut + 4.9t^2, with s = 2 and u = 24, you get,
4.9t^2 + 24t -2 = 0
Solution is t = (-24 + sqrt(576+39.2))/9.8 = 0.08 s
Total time = 4.98s
  • · Replies 36 ·
11K
  • · Replies 38 ·
