Register to reply
Tension and frequency
by warmfire540
Tags: frequency, tension
Share this thread:
warmfire540
#1
Jun14-08, 10:42 PM
P: 55
The G string of a guitar which should be 392 Hz is playing flat at 380 Hz. What percentage change in the tension of the wire is required so as to tune the string to 392 Hz?
I just need to help getting started on this one, I don't know how to relate tension to frequency without knowing lamda
Phys.Org News Partner Science news on Phys.org
An interesting glimpse into how future state-of-the-art electronics might work
Tissue regeneration using anti-inflammatory nanomolecules
C2D2 fighting corrosion
dynamicsolo
#2
Jun14-08, 11:19 PM
HW Helper
P: 1,662
The velocity of the waves on the string will be the product of the frequency and wavelength. Changing the tension in the string alters the velocity of the waves, but since the fundamental tone of the string is produced by a standing wave, that wavelength is constant. So you will not need to know it (or the length of the string itself).
warmfire540
#3
Jun15-08, 09:41 PM
P: 55
Quote Quote by dynamicsolo View Post
Okay, well where would I derive a formula to find the tension, or therefore the change of tension in this case?
Hurkyl
#4
Jun15-08, 09:46 PM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,091
Quote Quote by warmfire540 View Post
You don't have to know lambda in order to manipulate it algebraically.
warmfire540
#5
Jun15-08, 10:54 PM
P: 55
Quote Quote by Hurkyl View Post
How come? I don't get why we don't need lambda? What other equation is there? How do you do it "algebraically?"
dynamicsolo
#6
Jun15-08, 11:53 PM
HW Helper
P: 1,662
You have the wave relation
v = f lam.
For the untuned string, then, you have
v_1 = f_1 lam_1
and, for the properly tuned string,
v_2 = f_2 lam_2 .
But the length of the G string doesn't change, so neither does the fundamental standing wavelength at which it vibrates. So we have
lam_1 = lam_2 = lam .
If we now compare the wave velocities, we get
v_2/v_1 = (f_2 lam)/(f_1 lam) = f_2/f_1 .
So we don't need to know the length of the string or the fundamental standing wavelength.
You know the relationship between wave velocity, string tension, and string linear mass density, so you can work out the ratio of the tuned versus untuned string tension. (BTW, you don't need to know the linear mass density of the string either: that also will cancel out.)
From the ratio of the tensions, you can find the fractional tension change, and from that, the percentage of tension change in the string.
warmfire540
#7
Jun18-08, 11:56 AM
P: 55
Okay
Well from here i see that f2/f1 = 392/380 = 1.0316
So the tuned string's tension is 1.0316 times more than the untuned strings tension.
This is also seen as a 96.94%, or a 3.06% in tension.
dynamicsolo
#8
Jun18-08, 01:59 PM
HW Helper
P: 1,662
It is true that f2/f1 = v2/v1. But isn't the wave velocity equal to sqrt( T / mu ) ?
warmfire540
#9
Jun18-08, 02:27 PM
P: 55
Yeah..so we sub v for the sqrt( T / mu )
so f2/f1= sqrt( T2 / mu )/sqrt( T1 / mu )
1.0316=sqrt( T2 / mu )/sqrt( T1 / mu )
1.0642=(T2/mu) / (T1/mu)
1.0642=T2/T1
So T1*1.0642 = T2
This is a 93.98% difference between strings, where as the difference in percent is 6.02%
dynamicsolo
#10
Jun18-08, 02:38 PM
HW Helper
P: 1,662
That is close, but be careful about the definition. The question asks for the percentage change in the tension of the wire. This will be
(delta_T / T) x 100% = [ (T2 - T1) / T1 ] x 100% .
The fractional change is equivalent to
(T2 - T1)/T1 = (T2/T1) - (T1/T1) = (T2/T1) - 1 = 1.0642 - 1 = 0.0642 .
So your percentage change should be 6.42% . (Or is 6.02% just a typo?)
warmfire540
#11
Jun19-08, 12:06 PM
P: 55
Ah i See! thank you soo much!
Register to reply
Related Discussions
Parallel RLC circuit: find resonant frequency and Input at that frequency Introductory Physics Homework 7
Frequency of a particle? Frequency of what? Quantum Physics 4
Change in Tension & Fundamental Frequency of a String Introductory Physics Homework 2
Frequency output = sum of 2 frequency inputs (Digital) Electrical Engineering 9
Difference between applied tension and tension due to weight? Introductory Physics Homework 2
