Laplace transform question
by math_04
Tags: laplace, transform
math_04
math_04 is offline
#1
Jun14-08, 11:28 PM
P: 104
This has to do with the unit step function. The question is;
Sketch the function g(t) = 1 for 0<t<1 and is 0 for t>1.
Express g(t) in terms of the unit step function and hence or otherwise show that
L(g(t)) = 1/s^2 - e^-s (1/s^2 + 1/2)
2. Relevant equations
3. The attempt at a solution
I sketched the graph (see attachment below). Im guessing the unit step function is t(u(t) - u(t-1)).
I tried one way of getting that answer like this t( u(t-1) u(t+1) - u(t-1) ). Obviously it didnt work out. I think I need to get u(t) in the form u(t-a) so I can use the table of Laplace transforms and just read out of it. How do I manipulate this kind of functions?
Thanks.
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
Defennder
Defennder is offline
#2
Jun15-08, 12:08 AM
HW Helper
P: 2,618
This is from my notes:
In this case, the function should be u(t) - u(t-1).
The Laplace transform you should be using is [tex]L[f(t-a)u(t-a)] = e^{-as}F(s) \ \mbox{where} \ F(s) = L[f(t)][/tex]
Note that u(t-a) = f(t-a)u(t-a) where f(t) = 1. f is a constant function.
So you only need to find the laplace transform of 1 and add in the e^(-as) factor in front of it.
Register to reply
Related Discussions
Laplace transform question Calculus & Beyond Homework 7
[SOLVED] Laplace Transform question Calculus & Beyond Homework 10
Laplace Transform Question. Calculus & Beyond Homework 0
laplace transform question... General Math 7
Laplace Transform Question Calculus & Beyond Homework 3
