Finding the change in Rotational Kinetic Energy
The problem involves a sphere with a specified moment of inertia and an initial angular velocity. A torque is applied, resulting in a change in angular velocity, and the task is to determine the change in rotational kinetic energy.
  • Mixed
  • Participants discuss the relationship between torque, angular velocity, and rotational kinetic energy, with some exploring the need for additional information such as angle or torque in the calculations.
There is an ongoing exploration of how to calculate the change in rotational kinetic energy, with some participants suggesting that the change in angular velocity is sufficient for the calculation. Multiple interpretations of the problem's wording are being considered, particularly regarding whether the angular velocity is increasing or decreasing.
Participants note potential ambiguities in the problem statement, particularly concerning the interpretation of "changed by 4 rad/s" and the implications for calculating the change in kinetic energy.
crazyog
A sphere with a 3 kg * m^2 moment of inertia about an axis through its center has its angular velocity changed by 4 rad/s owing to a 2 N*m torque applied about that axis for 6s. If its initial angular velocity is 10 rad/s, the change in its rotational kinetic energy in J is...
The answer according to the book is 144 J.
1/2Iiwi^2 - 1/2Ifwf^2 = change in Ke
T=I(a)
The wording of the question is kind of throwing me off because i don't understand the part about the Torque.
Thanks
It will be helpful to you to know that there are analogies in rotational mechanics to the definitions and equations you learned in linear mechanics.
Back in linear mechanics, you have the definition of work:
W = F · delta_x
and the work-kinetic energy theorem:
W = KE_f - KE_i .
In rotational mechanics, the rotational work will now be
W_rot = (torque) · (delta_theta) ,
with delta_theta being the angle the object has turned through while the torque is applied.
The work-kinetic energy theorem still applies,
now with
KE_rot = (1/2) · I · (w^2) .
Ok so the initial KE_rot = 1/2 * I * (w^2)
= 1/2 * 3 * (10^2) = 150
I see what you are saying that W_rot = torque * delta theta
but how would that apply I am not given an angle?
and am I finding the W_rot and subtracting it from 150?
crazyog said:
A sphere with a 3 kg * m^2 moment of inertia about an axis through its center has its angular velocity changed by 4 rad/s … If its initial angular velocity is 10 rad/s, the change in its rotational kinetic energy in J is...
crazyog said:
… I am not given an angle?
Hi crazyog! :smile:
You don't need an angle or a torque or anything else for this part of the question …
You know it goes from 10 rad/s to 14 rad/s … so what is the increase in rotational KE? :smile:
Oh ok so when they say "changed by 4 rad/s" it means it is now 14 m/s
so that would be
1/2(3)(14^2) = 294 J
294 - 150 = 144 J
Thank you!
Oh, yes, quite so! Since they gave that information, I thought we'd need it somewhere. (Presumably, there are other parts to this problem...)
I wonder how they expected the student to know that the angular speed was being increased. The problem states that the "angular velocity (is) changed by 4 rad/s". You get a different magnitude for the rotational KE change if the angular speed goes to 6 rad/sec...
yes … you're right! … :smile:
Now I'm wondering why I assumed it was increasing! :redface:
And the change in angular momentum (rotational impulse) is
delta_L = (torque)·(delta_t) .
So the change in angular momentum is
delta_L = +/- (2 N·m)·(6 sec) = +/-12 kg·(m^2)/sec ,
so the new angular momentum would be either
L' = (3 kg·m^2)·(10 rad/sec) + 12 kg·(m^2)/sec
= 42 kg·(m^2)/sec
or
L' = (3 kg·m^2)·(10 rad/sec) - 12 kg·(m^2)/sec
= 18 kg·(m^2)/sec ,
which are consistent with final angular speeds of 14 or 6 rad/sec .
So the other information in the problem doesn't provide a clue either...
So a second valid answer would be -96 J for the change in rotational KE. (I think the solver for the textbook must have assumed the speed was increased.)
  • · Replies 33 ·
  • · Replies 21 ·
  • · Replies 16 ·
