Confirm Answers to Questions on Power Usage Calculations
The discussion revolves around power usage calculations, specifically focusing on how to compute kilowatt-hours based on a continuous power function over a 30-day period. The original poster presents two parts: approximating total kilowatt-hours using a Riemann sum and deriving an exact expression using integration.
  • Participants explore the use of Riemann sums and integrals to calculate total energy consumption. Questions arise regarding the correct application of these methods, particularly the need to account for time intervals and the number of terms in the sum.
There is ongoing clarification regarding the correct formulation of the Riemann sum for part A. Some participants have confirmed the correctness of part B while identifying issues in part A. The conversation reflects a productive exploration of the concepts involved, with participants questioning and refining their understanding of the calculations.
Participants are discussing the implications of using a continuous function for power over a defined time period, with specific attention to the assumptions made about time intervals in their calculations.
pooka
I am new to the forum,so if i posted the question not according to some specific format, i apologize.
Power companies typically bill customers based on the number of kilowatt-hours used during a single billing period. A kilowatt is a measure of how much power (energy) a
customer is using, while a kilowatt-hour is one kilowatt of power being used for one hour.
For constant power use, the number of kilowatt-hours used is calculated by kilowatt-hours=kilowatts * time (in hours). Thus, if customers use 5 kilowatts for 30 minutes, they'll have used 5 kilowatts * (1/2)hrs =2.5 kilowatt-hours.
Suppose the power use of a customer over a 30-day period is given by the continuous
function P(t) where P is kilowatts, t is time in hours, and t =0 corresponds to the
beginning of the 30 day period.
A.
Approximate, with a Riemann sum, the total number of kilowatt-hours used by the customer in the 30 days.
B.
Derive an expression representing the total number of kilowatt-hours used by the
customer in the 30-day period. (This expression should not be an approximation.)
for A:
I did R=720 sigma t=0 to t=720 f(t)
for B: i just did T(t)= integral sign 0 to 720 f(t)dt
Could someone confirm my answers? Thanks in advance.
Almost. But why does A have an overall factor of 720?
I thought that the Riemann sum from 0 to 720 would give me the total number of kilowatt used, so I multiplied that by 720 hrs to get kilowatt hours. Is part B correct then? Thanks for your help.
B is certainly correct. A has two problems. Suppose the time interval were only three hours and you know f(0), f(1), f(2) and f(3). How would you approximate the power used?
Dick said:
B is certainly correct. A has two problems. Suppose the time interval where only three hours and you know f(0), f(1), f(2) and f(3). How would you approximate the power used?
Hmm...I would add f(0), f(1), f(2) and f(3) up and times that sum by 3 to get kilowatt hours.
Maybe you would. I wouldn't. There are three one hour intervals. So I would write either f(0)*(1hr)+f(1)*(1hr)+f(2)*(1hr) or f(1)*(1hr)+f(2)*(1hr)+f(3)*(1hr). Those are Riemann sums. Put in numbers for f(t). Suppose e.g. f(t) is a constant 10kw. Then the exact answer is 30kw*hr. Do you see why what you are doing doesn't give the correct answer, even approximately?
Oh, I think I see what you mean. So for A, it should just be R=sigma t=0 to t=720 f(t).
Much closer. But now your sum has 721 terms in it and there are only 720 hours. And the units are still in kw. You need to multiply by hours somehow. Look back at the 3hr example.
So sigma t=0 to 719 f(t)* (t1-t0)? by t1-t0 i mean the increase in the number of hrs from the preceding hr which is 1 hr for each.
Why do you want to increase the number of hours? Each interval has only one hour in it. Just think about how you would approximate it using a pencil and paper. Multiply an approximation of the power usage over each hour by the interval (1 hr).
I think that it is 1 hr times sigma t=0 to 719 f(t)
Right! Could also be 1 hr times sigma t=1 to 720 f(t), yes? That would be just as good. The '1 hr' in the Riemann sum corresponds to the 'dt' in the integral.
yes it could also be 1 hr times sigma t=1 to 720f(t). Thanks so much for ur help and being so patient! :smile:
  • · Replies 22 ·
  • · Replies 24 ·
11K
