Register to reply
How Come Planets Don't Fall Into Stars?
by NYSportsguy
Tags: atoms, einstein, electrons, gravity, planets
Share this thread:
NYSportsguy
#1
Jun17-08, 02:43 AM
P: 104
How come planets don't fall into stars as they orbit them? Einstein said a "space-time" curvature is caused because of the gigantic mass of the stars....why don't the planets orbiting these stars just fall right into them?
Does it have something to do with the same reason why electrons never fall into the nucleus that they revolve around? Why does this not happen either?
Phys.Org News Partner Astronomy news on Phys.org
New mass map of a distant galaxy cluster is the most precise yet
Highest-precision measurement of water in planet outside the solar system
Satellite galaxies put astronomers in a spin
physixguru
#2
Jun17-08, 03:01 AM
P: 338
It is exactly the same analogy to the electron and nucleus theory.
The electron does NOT orbit the nucleus. Just look at the lowest energy orbital : the s-orbital. It is a sphere around the nucleus. So , prior to any kind of measurement, the electron is basically everywhere around the nucleus.
Same goes for any other orbital (ofcourse the have another shape)
QM proves us that the kinetic energy is higher when being closer to the nucleus, but the potential energy is lower (more negative). The sum of these two really yields a stable equilibrium throughout all energy levels.
According to classical law of thermodynamics any charged particle moving in a curved path should loose its energy continuously and fall into the nucleus but this does not happened as two different force acting which are known as centripetal and centrifugal forces and this was explained by Neils Bohr.
Planets are traveling at the speed necessary to keep from falling deeper into the gravity well. To demonstrate, take a marble and spin it around a large bowl. As long as the marble has the right velocity, it won't fall into the bowl but will continue to revolve around the bowl.
jimmypoopins
#3
Jun17-08, 03:32 AM
P: 65
Quote Quote by physixguru View Post
isn't this not correct?
i'm pretty sure the electon orbits the nucleus in an orbital (and spherical) pattern.
the earth and other planets orbit the sun in a semi-circular pattern. i'm pretty sure you can learn the laws involved in some fairly basic classical physics related laws.
i'm a math major and haven't studied the equations in a couple of years but it shouldn't be too hard to figure out what exactly is going on.
that, however, is correct, similar to how satellites orbit the earth.
jablonsky27
#4
Jun17-08, 03:44 AM
P: 74
Quote Quote by jimmypoopins View Post
no, electrons dont orbit the nucleus. as physixguru already said, only the s-orbital is spherical. other orbitals(p, d, f) have different shapes. p-orbital for example is 'dumbell' shaped. to derive these you need to have knowledge of quantum mechanics.
the planets revolve around the star in elliptical orbits. these can be derived from classical physics related laws.
Wallace
#5
Jun17-08, 03:57 AM
Sci Advisor
P: 1,253
Electrons can be described as orbiting around the nucleus in simple models, such as the Bohr model, that do a reasonable job of fitting to the data. As jablonksy pointed out though, in modern quantum mechanics (that does an even better job) this is not how electron orbitals are described.
jtbell
#6
Jun17-08, 05:35 AM
Mentor
jtbell's Avatar
P: 11,602
Quote Quote by NYSportsguy View Post
The Earth (for example) continuously falls towards the sun. It is also moving "sideways" with respect to the sun, so it continuously misses the Sun!
Imagine that you're suspended stationary far away from the sun, say at the distance of the Earth. If you simply drop an object from that location, it falls in a straight line and eventually hits the Sun. If you throw the object sideways, it doesn't fall in a straight line, but rather in a curved path. If you don't throw it very hard, it still hits the Sun, but not directly underneath you. If you throw it hard enough, it misses the "edge" of the Sun, whips around, comes back up in an elongated elliptical orbit, and whacks you in the back of the head! (assuming there's no "air resistance" from gases near the sun, of course)
We have an FAQ about this in the General Physics forum.
Why Don’t Electrons Crash Into The Nucleus In Atoms?
stevebd1
#7
Jun17-08, 06:02 AM
P: 608
The centripetal acceleration of Earth equals the gravitational pull of Sun at this radius. Basically-
[tex]\frac{v^2}{r}=\frac{Gm}{r^2}[/tex]
where [itex]v[/itex] is the angular velocity of the Earth in metres/second, [itex]r[/itex] is the Earths mean orbit radius in metres and [itex]m[/itex] is the mass of the Sun in kg. Both quantites are expressed in [itex]m/s^2[/itex]
The same equation can be used to explain why the moon doesn't fall into the Earth and why the ISS stays in orbit.
jablonsky27
#8
Jun17-08, 06:05 AM
P: 74
Quote Quote by stevebd1 View Post
where v is the angular velocity of the Earth, r is the Earths mean orbit radius and m is the mass of the Sun.
isnt v the linear velocity?
stevebd1
#9
Jun17-08, 06:07 AM
P: 608
If it's rotating about a point, I'm under the impression it's angular velocity-
http://en.wikipedia.org/wiki/Angular_velocity
jablonsky27
#10
Jun17-08, 06:15 AM
P: 74
its rotating about a point alright, but in the equation you posted, v is the tangential velocity that the earth has at any given point in its orbit. thats what i meant when i said linear velocity.
Kurdt
#11
Jun17-08, 06:21 AM
Emeritus
Sci Advisor
PF Gold
P: 4,982
v is the tangental velocity. jimmyp, if you're interested in electron orbitals look up spherical harmonics which describe the shape of orbitals in modern QM for quantum numbers l and m. They are of course solutions to the TISE in spherical polar coords.
stevebd1
#12
Jun17-08, 06:37 AM
P: 608
I stand corrected, the proper term for v is tangental velocity but the quantities and equations still stand.
stevebd1
#13
Jun17-08, 07:11 AM
P: 608
Based on the above equation, it seems like the following would apply when looking at the elliptical orbit of planets-
Due to the unlikely nature of a perfectly circular orbit, Earth is sometimes closer to the Sun. Because of conservation of angular momentum, [itex]J = vmr[/itex] where [itex]J[/itex] is the angular momentum (in Nms), [itex]m[/itex] is the mass of the Earth (in kg), [itex]r[/itex] is the mean orbit radius (in m), as the Earth gets closer to the Sun, [itex]J[/itex] & [itex]m[/itex] don't change but because [itex]r[/itex] reduces, [itex]v[/itex] increases and as a result, Earth's centripetal acceleration overcomes the gravitational pull of the Sun at this reduced radius and it manages to overshoot it's mean orbit radius as it continues it's orbit around the Sun. Again, because of the conservation of angular momentum, at this increased radius, [itex]J[/itex] & [itex]m[/itex] don't change but the increased [itex]r[/itex] means a reduced [itex]v[/itex] and the centripetal acceleration is overcome by the Suns gravity, pulling the Earth back into a reduced orbit and the process starts again.
physixguru
#14
Jun18-08, 02:37 AM
P: 338
'v' is the tangential velocity.NO two opinions about it.
Alan McDougal
#15
Jun18-08, 08:09 AM
P: 42
Planets do not fall into stars are due to space bending near the star and the law of momentum.
Eventually most planetary orbits will decay and said planet descends into the star the star will never lets its children escape.
Of course before the planet falls into most stars like our sun, it will go red giant and consume the poor planet in an orgy of fiery death
junglist
#16
Jun20-08, 02:38 AM
P: 21
Quote Quote by Alan McDougal View Post
is this true? ive read about the moon's orbital radius increasing by 4mm/year so is it likely that this would also be the case for planets orbiting stars?
does the mass of the sun decrease as it converts matter to energy? would this effect be greater than that of phenomenon that cause orbital decay (drag, etc)?
Wallace
#17
Jun20-08, 02:42 AM
Sci Advisor
P: 1,253
Quote Quote by junglist View Post
In general planetary orbits do not decay. In principle the orbit of a planet around a star gives of gravitational waves which will slowly decay the orbit but the key there is slowly. Any star would be looong burnt out before this effect would even be measurable.
junglist
#18
Jun20-08, 02:49 AM
P: 21
Quote Quote by Wallace View Post
are these gravitational waves due to surface irregularities?
if so, i understand you. :)
is this effect more or less significant than drag as the planet passes through dust and other material thats floating around?
Register to reply
Related Discussions
Net Charge of Planets and Stars Astronomy & Astrophysics 4
Planets and Stars Astronomy & Astrophysics 10
Are new planets and stars still forming? Cosmology 8
Are Planets Around Stars... Astronomy & Astrophysics 4
Planets around twin stars Astronomy & Astrophysics 7
