Thread Closed
Natural frequencies - theoretical vs COSMOS results
Share Thread Thread Tools
Jun17-08, 05:43 AM   #1
Hi all,
I am new to the forum and am despreate for the solution for my current task. I am given a canteliver beam with the dimention:
L =1250mm
W= 75mm
D= 30mm
E=200 Gpa
density = 7800kg/m^3
poison ratio=0.3
and I optained the first five natural frequencies from COSMOSWorks 2007, which are 15.7483, 39.2254, 98.4208, 241.795 and 274.422Hz respectively. Looks logical isnt it? However, these values are different from the hand calculated values and I really need to find out why.
The formula I used for hand calculation:
W^2=(1.875^4)(EI/density*area*length^4)
where I = (1/12)(bt^3)
Help needed, urgent!! Many thanks in advance
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jun17-08, 06:40 AM   #2
Recognitions:
What was different from your hand calcs? Could you possibly be off by a factor of [tex]2\pi[/tex]?
Jun17-08, 07:32 AM   #3
1st frequency for example, hand calculations give 5Hz while generated value shows 15Hz. This is a huge difference, and I need to know why if it is supposed to be different.
2 pie converts rad/s to Hz, not a crucial point in this case.
Jun17-08, 11:16 AM   #4
Recognitions:
What's the height of the beam?
Jun17-08, 12:16 PM   #5
height = depth = 30mm
Jun17-08, 04:40 PM   #6
Recognitions:
Gold Membership Gold Member
I modeled up the beam in ANSYS and got the same results for the vibrational modes that you got in COSMOS.
Perhaps this paper can help, it goes through the analytical derivation of vibrational modes for a cantilever beam.
http://em-ntserver.unl.edu/Mechanics...hweb/Beams.htm
Jun18-08, 02:27 AM   #7
Many thanks bro, problem solved!! It was due to the mode constant
Scott Whitney's suggestion
Total motion: 325Htot.scm
1st mode: 325h1st.scm
2nd mode: 325h2nd.scm
3rd mode: 325h3rd.scm
4th mode: 325h4th.scm
Book's suggestion (I tried with this and got it)
1st mode: 3.52
2nd mode: 22
3rd mode: 61.7
Thread Closed
Thread Tools
Similar Threads for: Natural frequencies - theoretical vs COSMOS results
Thread Forum Replies
How To Fing Angular and Natural Frequencies WITH ANSYS ?? Mechanical Engineering 2
Age of Cosmos/Size of Cosmos? Cosmology 1
Natural and Fundamental Frequencies Classical Physics 1
Cosmos General Discussion 23
Proof that (2n)!/[n!(n+1)!] is natural for natural n General Math 13
