Understanding how energy disappears
  • Context: Undergrad
  • Thread starter Thread starter esvion
    Energy
The discussion revolves around the concept of energy in the context of the "big freeze" scenario for the end of the universe, exploring the implications of energy conservation, the fate of energy, and related phenomena such as the behavior of photons and radio waves. The scope includes theoretical considerations and conceptual clarifications regarding energy dynamics in an expanding universe.
  • Some participants question where energy goes in a "big freeze" scenario, noting that while energy cannot be destroyed, it becomes diluted as the universe expands.
  • One participant suggests that energy dissipates as heat, with light bulbs converting emitted photons into heat energy upon burning out.
  • Another participant emphasizes that energy is not conserved on a cosmic scale, citing that the total energy can change due to the expansion of the universe and the behavior of dark energy.
  • There is a discussion about the nature of radio waves, with some participants clarifying that radio waves are electromagnetic waves and not composed of electrons, challenging a misconception about their propagation.
  • Some participants express uncertainty about the implications of the second law of thermodynamics on the existence of complex structures in the universe.
Participants generally agree that energy cannot be destroyed and that it spreads out in an expanding universe, but there is disagreement regarding the conservation of energy on a cosmic scale and the implications of the second law of thermodynamics. The discussion remains unresolved on several points, particularly regarding the fate of energy and the nature of radio waves.
Some claims about energy conservation depend on specific definitions and contexts, such as local versus cosmic scales. The discussion also touches on the complexities of energy dynamics in an expanding universe, which are not fully resolved.
esvion
I've been reading about the possible ends to the universe and I came across the "big freeze".
http://en.wikipedia.org/wiki/Big_Freeze
In this scenario, all the energy in the Universe goes out and the Universe is cold and desolate with no stars. But the law of conservation of energy states that energy cannot be destroyed. Where did all this energy go then?
It's like when I punch something imaginary in mid air. What happens to the energy momentum in my fist after I am done punching? Does it vibrate the air molecules around me on such a small level into infinity?
I see energy disappear around me all the time, such as when a light bulb runs out. What happens to the photons that the light bulb was giving off the entire time before it burnt out?
Any help would be appreciated. Thanks!
Edit:
How can electrons go through houses and what not. I was wondering about radio waves and how they're just electrons moving out of the broadcasting location. Do these electrons also continue forever into space? And how do they have enough energy to go on forever?? More importantly, can these radio wave electrons get bonded to something in some sort of electric-chemical reaction?
Space news on Phys.org
esvion said:
Edit:
Radio waves are not electrons. They are electromagnetic waves, just like visible light, only with longer wavelengths and can be "diffracted" rather easily through openings like doors and windows.
Next time, you should not ask two very different questions in a single post/thread. It makes it confusing when people start responding to it.
Zz.
You are right - the energy of the universe has to be constant. In a "Big Freeze" scenario, as it says in the Wik link, the low temperature is due to the size of the univers: as the universe expands, the energy spreads out into more and more space, eventually becoming so diluted that the energy density is very low.
This, btw, is the reason that the cosmological micrwoave background radiation is so low of an energy (2.4 K iirc) despite being an 'image' of moments after the big bang.
Most forms of energy are eventually dissipated as heat. A light bulb emits light, which is absorbed by your walls and floor and heats them.
When you punch the air, the energy is absorbed by your shoulder and muscles. That's why it hurts!
The energy does not vanish. It is just spread out more or less uniformly throughout an ever-growing universe. At the end of this scenario the whole universe will have the same temperature (slightly above 0 Kelvin), almost all matter will have collapsed to black holes which are so far apart (and still drifting away) from each other that there is almost no gravitational force left between them. The energy has just developed to a state where it cannot be transferred anymore because it is in thermal equilibrium.
But this scenario can only take place if the total mass in the universe is less than some critical value. If there is enough mass the universe will collapse due to its gravitation.
Yes. The kinetic energy of your fist will transform mostly into molecular chaotic movement = heat energy. Everything eventually ends up as heat
The photons are absorbed somewhere and transform their energy to heat eventually.
Radio waves are electromagnetic waves - just the same as light. Electromagnetic waves do not consist of electrons but of photons.
It is not generally known the fact that, even under the theory of BigBang, energy is not constant, is not conserved at large scale.
Only at local scale the conservation of energy is stated.
quoting from here:
http://preposterousuniverse.com/writings/cosmologyprimer/faq.html#energy
"Is energy conserved in an expanding universe?
This is a tricky question, depending on what you mean by "energy." Usually we ascribe energy to the different components of the universe (radiation, matter, dark energy), not including gravity itself. In that case the total energy, given by adding up the energy density in each component, is certainly not conserved. The most dramatic example occurs with dark energy -- the energy density (energy per unit volume) remains approximately constant, while the volume increases as the universe expands, so the total energy increases. But even ordinary radiation exhibits similar behavior; the number of photons remains constant, while each individual photon loses energy as it redshifts, so the total energy in radiation decreases. (A decrease in energy is just as much a violation of energy conservation as an increase would be.) In a sense, the energy in "stuff" is being transferred to the energy of the gravitational field, as manifested in the expansion of the universe. But there is no exact definition of "the energy of the gravitational field," so this explanation is imperfect. Nevertheless, although energy is not really conserved in an expanding universe, there is a very strict rule that is obeyed by the total energy, which reduces to perfect conservation when the expansion rate goes to zero; the expansion changes the rules, but that doesn't mean that anything goes.
The original question of this post is about Big Freeze supported on 2nd law of thermodinamics.
But have a look to the universe and what do we see ?
If 2nd law holds than Life itself is not possible.
The universe is going on the path of constructing more and more complex structures. Starting on CMB quasi-homogeneus state the universe is now a much more non-homogeneus site.
So the 2nd law of Thermodynamics is not holding.
Universe decided to evolve the opposite way.
You're thinking of entropy in the wrong way. Entropy is not a system tending to disorder - disorder is merely a metaphor for entropy. A better way of thinking of it is as a degradation of energy. Amounts of energy are becoming unusable due to irreversible processes.
As an aside - the entropy decrease due to life on Earth is much lower than the increase caused by general processes. There's an quantative article on it somewhere. . . .
Found the abstract: http://scitation.aip.org/getabs/servlet/GetabsServlet?prog=normal&id=AJPIAS000076000011001031000001&idtype=cvips&gifs=yes
Quoting from from the abstract (I don't have access to the paper without paying) :
"Quantitative estimates of the entropy involved in biological evolution demonstrate that there is no conflict between evolution and the second law of thermodynamics."
I don't know what is the contents of that paper, but I'm able to say:
The living organisms use/consume free energy to construct complex structures.
They can hold only in a free and rich energy environment, not a closed system.
As you say,it is true "Amounts of energy are becoming unusable due to irreversible processes"
it holds clearly that the universe is agreggating matter/energy to provide such rich energy environments.
Smart Universe.
If my understanding is correct, which it may not be, wouldn't super-massive black holes be attracted to one another? So although a thermal equilibrium may be reached, the gravitational force of the black wholes would draw them all together? Leading to another possible big bang?
I mean, space, in essence, it a very complicated homogenous mixture, so although heat may be thoroughly dispersed, the density is only an average, not constant?
I'm sorry if my post was confusing :)
Hayley
Hayley
The black holes would be attracted to each other. But because the distance between them may be so great the force between them will be less than the dark energy expansion "forces" - just the same way that galaxies behave just now.
The density is average but the fate of the universe depends on this average density. If it is greater than the so called critical density then there will be enough force to pull the universe in together leading to a "Big crunch". If it is less tha critical density then what I first described will occur. And if it equals the density then there will be a form of equilibrium.
Ah, thank you. That cleared things up a bit.
Hayley
  • · Replies 24 ·
  • · Replies 25 ·
  • · Replies 33 ·
10K
